E34 (1989 - 1995)
Old 02-11-2013, 07:47 AM
907URO 907URO is offline
Mein Auto: 2005 Audi Allroad
Question Good buy?
I hear a heater core is a pain to replace though. http://anchorage.craigslist.org/cto/3608841161.html
Old 02-11-2013, 08:07 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
I just had to have my heater core replaced. I looked and the DIY and decided it wasn't for me, so I had my indy mech do it. It cost $635 including a new cabin air filter.
His description of the possible leak at the O-rings sounds a little fishy because of his statement that it "is leaking past its O-rings and needs to be fixed to blow heat real hot."
A leaking heater core will not change how hot the air coming out is unless it has leaked enough coolant that the entire system is low. If that is the case, then an engine overheat is entirely possible.
A leaking heater core manifests in one of two ways, or both. Firstly, you will smell a sweet, coolant smell out of the vents when the heat is turned on. Secondly, if the leak is severe enough, you will get fog on the inside of the windshield that will not go away with the defroster and can leave an oily film. One last way to tell is by a puddle of coolant under the car by the transmission area. This is where the heater core box drain comes out.
Anyway, look at the car with your eyes "wide open" so to speak. I don't know how many reputable indy mechs you have there, but, in my opinion, it would be worth the $75-$100 it would cost to have a pre-purchase inspection (PPI), especially if you are not familiar with the E34 BMW.
Good luck on your purchase it you get it.
PS: BTW, I spent a year stationed at King Salmon AFB there in '81-'82. I have some of the greatest memories from there.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-11-2013, 08:23 AM
CarDriver's Avatar
CarDriver CarDriver is offline
Mein Auto: 1992 525it /2004 ML350
I did my own heater core and it was a pain in the butt-ox... It took about three hours to complete. It is a DIY but deffinitely a PAI. If the car is sound eccept for that and the price is right, go for it.
Edit,
If the sellers only clue to needing a new heqater core is that the heat is not blowing real hot... It may just need a new cabon air filter.
Old 02-11-2013, 08:38 AM
BMR_LVR's Avatar
Humble E34 lover
And/or his t-stat could be sticking open as well.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-11-2013, 10:12 AM
CarDriver's Avatar
And there that... LOL...
Old 02-11-2013, 11:02 AM
if I go look at it how can I tell if the t-stat is stuck open? Where would I see leaks from heater core? I will check for foggy windows.
Old 02-11-2013, 01:02 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
let it idle and if it never gets to full operating temp, like half way warm, then its stuck open.
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 02-11-2013, 01:30 PM
so check for temp and would i see any fluid leaks? where?
Old 02-11-2013, 01:42 PM
Monsignor's Avatar
Mein Auto: Sig
stuck t-stat would not cause a fluid leak
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-11-2013, 01:48 PM
sorry i ment if the heater core was leaking where would i see leaks? Also I own all audi's and you have to use special coolant. Should I be looking for a specific coolant color?
Old 02-11-2013, 03:15 PM
Monsignor's Avatar
Mein Auto: Sig
could be any color. I've seen it look sorta oily... it'll just look wet really.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-11-2013, 06:17 PM
BMR_LVR's Avatar
Humble E34 lover
If it's leaking heavily, the passenger side floorboard carpet may be wet. If it happens to be parked on concrete, then a moderate to severe leak will manifest by coolant dripping on the driver's side of the transmission. That is where the drain for the heater core box comes out.
Usually, if the heater core is leaking, you will smell it when you turn the heat on.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 02-11-2013, 09:41 PM
BMWFatherFigure's Avatar
Old School
+1 on smell. Possibly seller has no idea what he is talking about. Only use genuine coolant.
Current:
E38 Parts Car
Previous:
Old 02-12-2013, 03:18 AM
CarDriver's Avatar
Even if she needs an HC, for a grand it may be worth it if all else is in good order...
