Z4 Roadster (E85) Resetting Oil Change Readout - Bimmerfest - BMW Forums
Old 02-11-2013, 09:30 AM
Sodgod65 Sodgod65 is offline
Mein Auto: 2003 Z-4
I just change oil in my 2003 Z-4 and have forgotten how to reset my computer for next oil change. I'd appreciate some help. Thanks.
Old 02-11-2013, 09:36 AM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
http://bit.ly/WESU3F
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 02-11-2013, 03:49 PM
wilem wilem is offline
fixin stuff
Mein Auto: z4
Z4 2003-2006 Press and hold left hand button between gauges. Turn ignition switch to the "ON" position. Keep holding button until "OIL SERVICE" or "INSPECTION" is displayed. Release button. Press and hold button again until "RESET?" is displayed. Press and hold button again for at least 3 seconds. Turn ignition off.
William
Old 02-16-2013, 11:47 AM
JBBIII JBBIII is offline
Mein Auto: 98 M Roadster & 03 Z4
Peake makes a great little fault reader/reset tool. price was 95$ when i got mine but the first time you use it and do not have to go to the stealership it pays for itself.
Old 02-16-2013, 06:05 PM
shipkiller's Avatar
shipkiller shipkiller is offline
Underway on Nuclear Power
Mein Auto: Me
http://www.shipkiller.com/Instrument...Procedure.html
How does something immoral, when done privately, become moral when it is done collectively?
Furthermore, does legality establish morality?
Slavery was legal; apartheid was legal; Stalinist, Nazi, and Maoist purges were legal. Clearly, the fact of legality does not justify these crimes. Legality, alone, cannot be the talisman of morel people. - Walter E. Williams
Old 08-06-2014, 04:25 PM
Triaker Triaker is offline
Mein Auto: 2007 BMW Z4 3.0si
OK, just had my oil change, put in 7 quarts (well, 6.9) as per instruction. Went to reset my oil change, and now when I start the car and check the oil, it says 15,500 to next oil change, but the word INSPECTION shows now in the display. Also it only shows the electronic dipstick at half-full. Do I need to just drive around some more? The manual says only 6.9 quarts of oil to fill it.
2007 Z4 3.0si
Old 08-08-2014, 09:35 AM
Any help? Suggestions? Bueller? Bueller?
2007 Z4 3.0si
Old 08-08-2014, 01:57 PM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Last oil change I put in the correct amount. The electronic oil gauge showed down by 1 increment. I drove the car for a couple of days and the gauge changed to showing full and has been showing that for the past month. If you know you put the correct amount in you have two choices, add a bit more until the gauge reads full or don't sweat it and just make a mental note of where the "full" reading is.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 08-08-2014, 03:29 PM
shipkiller's Avatar
Mein Auto: Me
If you put the proper amount of oil in the engine, you DO NOT add more oil to make the electronic gauge show full.
Old 08-08-2014, 09:13 PM
JPBJR1234 JPBJR1234 is offline
Mein Auto: Z4
Always give it a couple of days of driving. Also when you check it drive at least 6-7 miles. If you added the correct oil requirements do NOT add any more oil!
