E30 (1982 - 1993)
Old 02-11-2013, 06:46 PM
AndrewZ's Avatar
AndrewZ AndrewZ is offline
Super Moderator
Mein Auto: 91 E30
Slight Overheating
Two days ago we did the timing belt, water pump, fan clutch, and thermostat and a few hoses. Car was running fine till today. The temp gauge goes up to 3/4's and then the electric fan kicks in and keeps the temp down.
Am I possibly looking at bad radiator? No leaks, coolant level seems fine. It only does this at stop lights.
Thanks in advance
Old 02-11-2013, 07:18 PM
hornhospital's Avatar
D'oh, You Kids!
Your fan clutch is shot. New? That definitely is the symptom of a non functioning fan clutch. Test it.
Quotes to live by:
Old 02-11-2013, 07:51 PM
BMWFatherFigure's Avatar
Old School
Thermostat not opening fully; part blocked radiator; air in coolant.
Current:
E38 Parts Car
Previous:
Old 02-11-2013, 08:04 PM
D'oh, You Kids!
^This is the give-away that it's the fan clutch. If it were a stuck thermostat or blocked radiator it would overheat regardless of speed.
Quotes to live by:
Old 02-11-2013, 08:36 PM
Old School
OP says 'did...fan clutch' I guessed he meant new. Maybe I misread.
Current:
E38 Parts Car
Previous:
Old 02-11-2013, 09:22 PM
D'oh, You Kids!
Yeah, I read that, too, but there's very little chance it's anything but the clutch judging from the symptom. Not disagreeing with you.
Quotes to live by:
Old 02-11-2013, 11:55 PM
Old School
No prob HH, I guess we will just have to wait and see..................
Current:
E38 Parts Car
Previous:
Old 02-12-2013, 05:29 PM
AndrewZ's Avatar
Super Moderator
Mein Auto: 91 E30
Yes, fan clutch is brand new along with the thermostat.
Old 02-12-2013, 11:56 PM
Old School
Radiator or air in the system is my guess.
Current:
E38 Parts Car
Previous:
Old 02-13-2013, 11:21 AM
AndrewZ's Avatar
Super Moderator
Mein Auto: 91 E30
I'll try to bleed the system again and go from there.
Old 02-13-2013, 06:30 PM
Old School
Do it with the heater on full heat - fast fan speed. Are you sure about the radiator?
Current:
E38 Parts Car
Previous:
Old 02-14-2013, 10:14 PM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
Andrew, if the fan clutch was not stored in the upright position it can malfunction or wear prematurely... Where did you source the FC?
Old 02-15-2013, 11:21 PM
cmac2012's Avatar
cmac2012 cmac2012 is offline
Renaissance Dude
Mein Auto: Two 1987 325i, 430K, 211K
Not sure what your boneyard scene is like but out here I'd find a decent looking used fan clutch, put it on, and if it made no difference take it back for credit. If it makes a difference, points to the problem. Of course it could be a defective unit also.
Old 02-17-2013, 06:28 AM
AndrewZ's Avatar
Super Moderator
Mein Auto: 91 E30
BMA in Glendale. I bleed the system again yesterday, and so far it's been fine but I haven't really been at any stop lights. Today will be the test on my way home from work.
Old 02-26-2013, 08:58 AM
AndrewZ's Avatar
Super Moderator
Mein Auto: 91 E30
Well, it still was overheating after my last post so I bought a new temp sensor that goes on the thermostat housing and finally it has stopped overheating. For the past week, the needle stays between a quarter and half.
Old 02-26-2013, 11:09 AM
7pilot 7pilot is online now
Git
Mein Auto: 90 Ford Tempo
Sounds like you changed the temp gauge sender, but the coolant circuit finally burped the trapped air.
m
