Old 02-12-2013, 06:15 AM
My Black Beauty My Black Beauty is offline
Allen
Mein Auto: 740IL
Speedometer Not Working
The speedometer on my 95 740il went out last week. It was acting crazy last month and stopped working a couple of times. I thought it was a ground problem at first, because it would only mess up when it rained. I then had new ABS sensors put on all tires, which didn't help. My other gauges have started to go crazy as it last for about a minute before going back to normal. When I ran the instrument panel test, everything worked including the speedometer. No ABS light, as my ABS/speed sensors are working fine, and I replaced my battery a couple months ago. Has anyone else had this problem before, or have any suggestions?
Allen
Old 02-13-2013, 12:26 AM
BMWFatherFigure's Avatar
Old School
ABS sensors do not work the speedo. It runs off a sensor on the crown wheel. Start checking there.
Current:
E38 Parts Car
Previous:
Old 02-14-2013, 04:55 PM
upallnight upallnight is offline
Mein Auto: BMW, Lotus, Porsche
It could be the VSS Vehicle Speed Sensor.
Old 02-14-2013, 08:32 PM
Allen
Mein Auto: 740IL
Speedometer not working
Thanks, is the crown wheel attached to the trans? I tried to find a picture of it in hopes of checking the speedo sensor?
HTML code is Off
