E46 (1999 - 2006)
Old 02-12-2013, 08:24 AM
BROOKSBC's Avatar
BROOKSBC BROOKSBC is offline
Mein Auto: 01 BMW 330i
Post CEL Codes with NO light
I recently had issues with misfires rough idle and oil leaking. I had 12 codes and my dash light was on. I replaced the CCV and all connecting hoses and the post cat O2 sensors. The oil leak was coming from a the broken hose that connects the CCV to the dipstick.
Now i dont seem to have any running issues at all. Idle has smoothed out and is constant along with the engine itself is running quieter and smoother. The oil leak was repaired....
BUT....now i have the following codes that dont seem to want to clear but yet they dont throw a CEL on the dash.
P0174 Bank 2 Lean
P0171 Bank 1 Lean
P0369 Exhaust camshaft position sensor
P0128 Thermostat Temperature Below regulated
P1193 PostCat Fuel Trim System Bank 2
Do i have a problem i wont see feel or hear? Should i just clear the codes and see if they return?
The last 3 codes appeared after i did the mentioned repairs. The top 2 were there prior to. My car has also passed emissions testing after the repairs as well.
Old 02-12-2013, 08:29 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
Having stored codes doesn`t always trigger a CEL. Did you clear the codes recently ?
The road goes ever onward....
(R.I.P. Jever)
Old 02-12-2013, 08:30 AM
BROOKSBC's Avatar
I haven't cleared them since i did the repairs because i wanted to see what codes would clear on their own after the work.
Old 02-12-2013, 08:37 AM
Fast Bob's Avatar
Keeping it surreal
I suggest clearing them all, and see if any return....
(R.I.P. Jever)
Old 02-12-2013, 08:59 AM
BROOKSBC's Avatar
Just re scanned on a cold engine and only the top 2 codes were present. I reset them.
Sent from my SAMSUNG-SGH-I747 using Bimmer App
Old 02-12-2013, 11:41 AM
BROOKSBC's Avatar
Just re scanned on a warm engine and I have 2 codes
P0365 and P1191.
Old 02-12-2013, 01:07 PM
Fast Bob's Avatar
Keeping it surreal
P0365 is Exhaust Cam Sensor
P1191 is Pre-Cat 02 sensor
There IS, however, a wrinkle attached to these 2 codes showing up together, to wit:
Your VANOS seals are probably shot, which allows the cams to go to full advance prematurely, triggering the above codes. The twist is that they`re *phantom* codes, there`s probably nothing wrong with the sensors, they`re being tricked by the cams advancing at the wrong time.
New VANOS seals will cure several problems....
(R.I.P. Jever)
Old 02-12-2013, 10:20 PM
heztheone heztheone is offline
Mein Auto: ///M
it could be as simple as a bad rewiring (in case u unplugged any wire while doing ur CCV). try unplug/plug tight everything you might have removed, clear your codes and check back.
same thing happened to me when i was cleaning my ICV/TB, got some codes, double checked everything, cleared codes, everything running smooth now.
if not, check your VANOS as Bob said
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
