E46 (1999 - 2006)
Old 02-12-2013, 05:51 PM
iskoos's Avatar
iskoos iskoos is offline
Coupe OR Never
Mein Auto: '02 - 325ci
Vanos Piston Cover Bolt WASHERS...
These are the large (Inch in diameter) hex bolts that cover the Vanos pistons (just under the valve cover).
Each one has an aluminum washer. Do they NEED to be replaced during the Vanos seal replacement???
I got pretty much everything to do the job but I do not have those washers. I checked the Beisan website and they don't say anything about replacing those washers.
So use the same washers?
Old 02-12-2013, 07:16 PM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
Just re-use the washers, they do not need to be replaced.
Old 02-12-2013, 07:54 PM
iskoos's Avatar
Coupe OR Never
I was going to send you a PM if I didn't see your reply here
Thanks...
