E90/E91/E92/E93 (2006 - 2013)
Old 02-12-2013, 09:50 PM
jaji90 jaji90 is offline
Mein Auto: 328i Hopefully
Exclamation Before buying a salvage... 2007 328i 50k miles
Hello everyone! I recently stumbled upon a good deal on a 2007 BMW 328i with only 50k miles, problem being that the car has a salvage title. According to the seller, only and ONLY the side airbag on the passenger side deployed (not the one on the dashboard). My question is if this were to be the case, and that all other airbags happen to be intact; would a simple airbag light reset work in order to return the vehicle to normal functioning of the rest of the airbags? I obviously wouldn't buy the vehicle if the other bags happen to be compromised. The price is below 11k, and I'm aware that only liability insurance would cover it. I've had experience with only one salvage vehicle that was involved in a fender bender and no airbag deployment.
Old 02-13-2013, 06:48 AM
sunny5280 sunny5280 is offline
Mein Auto: 2007 X5 4.8i
Do you know what caused the airbag to deploy? I'm also not clear on whether the deployed airbag has been replaced or if it still needs repaired. If it was who did it? If the warning light is illuminated that's an indication whoever performed the repair was unqualified to do so.
I would also thoroughly investigate any claims made by the seller. In such a situation I would want to have some form of indpendent confirmation of their claims. I highly recommend a PPI from a qualified mechanic who specializes in BMW's. It would probably also be a good idea to have a body shop take a look at it as well.
Old 02-13-2013, 07:28 AM
Last Sight's Avatar
Last Sight Last Sight is offline
Mein Auto: 09 328xi E92 6MT "BLTxi"
Could you provide more information on the car? (I'm only assuming it was involved in an accident causing an airbag deploy).
Assuming it was involved in an accident, as an EMT, I have done trainings on proper extrication of patients involved in car accidents. Part of those trainings touched on the issue of, if one airbag deploys, there is a possibility the others can go off unless fixed/reset correctly. Is the airbag fixed? If not, you shouldn't drive the car as any of the other airbags in the car could go off. Either way, actually, you shouldn't because the light is still on.
09 328xi 6MT: Montego Blue Metallic, Saddle Brown Dakota Leather, wood trim, iDrive, Sport Pkg, Cold Pkg, Premium Pkg
Previous Rides:
'11 Ford Fusion SEL
'08 Honda Accord Coupe
'01 Saab 9-3 2.0T
Old 02-13-2013, 07:33 AM
floydarogers's Avatar
Pedant and Curmudgeon
Mein Auto: 335d
As others have said: why did the airbag deploy? If it was a frontal collision, it's possible the driver's airbag didn't deploy because he was belted and the passenger wasn't, or because it was a right-side hit.
In either case, you must be ABSOLUTELY SURE that the frame rail is not compromised (and they just did a cosmetic fix to the fender/bumper/door). Which means that you need to carefully investigate the crash and subsequent body shop repairs.
Old 02-13-2013, 07:41 AM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is online now
Flying monkey herder
Mein Auto: Daihatsu Terrios
the airbag needs to be replaced or else the SRS system will not reset, and rest of airbags may not function. you cannot reset the light without replacing the airbag
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Present: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Old 02-13-2013, 08:31 AM
CALWATERBOY's Avatar
CALWATERBOY CALWATERBOY is online now
Mein Auto: 2009 E93 N54
Airbags sometimes deploy for no reason at all. Nobody knows what an airbag's gonna do.
You know what an airbag's gonna do?
And once deployed, the stain of that suspicious event is forever upon that VIN. Foo....foo! A delicious price for damaged goods is applied - you may buy with confidence.
But, to put your mind at ease, >might< be a good idea to look for hidden damage before you part w/cash!
Old 02-14-2013, 12:38 PM
Just a quick update, the car was hit from the right side. The guy selling the car owns a shop and said he can actually have the airbags replaced and the system reset. I believe these repairs *might* be included in the sale price. However, he did comment on checking out the car and then decide upon if I want to buy it or not. I also looked up a reputable BMW indie shop, not too far from where this guy's shop is. So, hopefully everything checks out and there are no other major issues with the vehicle.
Old 02-14-2013, 12:45 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: BMW X3
I bought one five years ago claimed to be damaged engine under warranty, repaired by BMW and with salvage title
Bought the car, 2 months later all sort of issues.... found out the car was FLOOD damage hence engine ceased
The lesson I leanrt : DIG DEEPER, don't scratch the surface... find out what the insurance company, ask selelr for permission to ring and find out why !!!
06 130i
07 320i
08 E92 325i
Bicycles: Giant TCR Advanced Zero, Argon 18 Krypton
NEXT CAR : A PORSCHE
Old 02-14-2013, 12:50 PM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: E90 335i xDrive
Are you that desperate to get into a car with unknown history with an apparent accident to boot at the same time? I don't wanna sound like your financial advisor, but I think you are just antsy to burn 11K in your pocket.
My car has been involved in a front end collision, however the impact vector and the speed I was traveling at didn't trigger the airbags deploy.
Well my car has now the lower subframe replaced, passenger side rail replaced, and driver side rail straightened.
I still don't have my car back so I can't tell you if it's been fixed and as good as new, but unfortunately, I don't think it will be as new once I get it.
BMW CCA Member 454031
2011 BMW 335i xDrive 6-speed manual thrills and whistles courtesy of the N55
Save the manuals
Old 02-14-2013, 01:01 PM
Not quite, that's why I'm looking as much as possible into it. Why pass up a "fair deal"? The BMW shop I'm thinking about taking it for the PPI has an exhaustive listing of what they check, so they'll be able to see if anything is out of order. As well, when I get to see the car I'll take a snapshot of the VIN. Usually, some insurance companies have their previous listings still up online that show the car's primary damage as well as pictures (just in case the seller does not have these).
Old 02-14-2013, 01:27 PM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Mein Auto: 2009 335i xDrive coupe
Hey, you saw mine at the Lime Rock ride. Except for the fact that the paint in the repaired area isn't orange-peeled, you couldn't have said where the repair ended and the original body started.
Still drives just as nice as when it was new, 15k miles after the accident.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3.
ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009
Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion
Old 02-14-2013, 01:40 PM
lqaddict's Avatar
Salz und Pfeffer
Zooks, I am not arguing the quality of the repairs, I am pretty sure when I get my car back hopefully tomorrow I will eat my words, we shall see
