Can someone tell me more about this engine light code please? - Bimmerfest - BMW Forums
Old 02-13-2013, 01:39 PM
CJ645Bern's Avatar
CJ645Bern CJ645Bern is offline
youtube.com/lidlgangsta
Mein Auto: 05' 645ci & 01' z3
Auto 2005 645ci
Planned on trading her in before anything came up and with my luck, the engine light came on and got these codes. Can someone tell me more please. Like how bad it Is and how much to fix. Thanks so much.
Po300 random misfire 7 &3 misfiring po303 po307
Sent from my SAMSUNG-SGH-I747 using Bimmer App
live fast, drive faster
2010 Acura TL (daily driver)
2005 BMW 645ci Coupe (traded for TL)
2001 BMW z3 3.0i vert' (TOTALED RIP)
1991 NISSAN 300zx 2+2 (gave to brother)
2007 BMW z4 (traded for 6er)
Old 02-13-2013, 07:51 PM
HerbP HerbP is online now
It could be fuel related, but have you not been getting quite a bit of moisture lately? Have the plugs or coil packs been serviced lately?
Good Luck!
Old 02-13-2013, 08:15 PM
CJ645Bern's Avatar
Good Luck!
No none of that has been serviced. And what do u mean have i not been getting moisture kately? If its fuel related what do u suggest I do? I only go to bp sunoco or shell which is where the guys on this forum recommended. Thanks for the reply!
Old 02-13-2013, 08:32 PM
I thought that your area might have been hit recently with a winter storm. The misfire could be fuel related, or spark related. If the problem is fuel, a good injector cleaner such as Techron might help. The fuel filter could be clogging, robbing fuel from the engine. If you have access to a fuel pressure gauge, check to see if your fuel pressure is up to spec.
If the problem is spark related, try moving a few of the easily accessible coil packs around. You could swap number 1 & 3, & 6 & 7. If the misfire follows the moved COP's, you found your problem. If you decide to swap the COP's, add some die-electric silicone to the inside of the springs. This will help corrosion from moisture, from forming on the plugs.
Good Luck
Old 02-13-2013, 08:39 PM
CJ645Bern's Avatar
Good Luck
Ahh yes. It snowed but it was bad. An inch or two. Its currently snowing right now. So the snow can be a possible problem too? And can I still drive it?
Old 02-14-2013, 10:10 AM
petros2r's Avatar
petros2r petros2r is offline
Ducati fills my BMW's gap
Mein Auto: '05 645ci
I would get the same codes from time to time. After resetting the "Check Engine" light and throwing a bottle of Techron cleaner into almost empty gas tank the code does not come back. In fact, I came to a service shop once right after re-setting it and they plugged in their fancy computer and said that there is not even a thread of a problem (normally it's recorded deep in the computer and the bmw service can tell that you've cleared the code)... go figure?
I have gotten a thermostat replacement twice because of the codes like that. Thankfully under warranty.
Honestly, I think is a computer glitch or something like that.
Invest in a pocket OBD-2 reader ($50 at Autozone) and re-set / clear those codes (I do once or so per year).
2005 Ducati Monster S2R 800
2005 BMW 645ci Cabriolet - SOLD
2013 Lexus RX 350 F Sport
Old 02-14-2013, 05:01 PM
Techron is on sale at O'reilly's for 3.99 a bottle. That is a steal!!!!!!!!!!!!!!!!!!!!!!!
Old 02-14-2013, 05:31 PM
CJ645Bern's Avatar
That's what ill do then. Hoping for the best. Thanks a lot
CJ645Bern's Avatar
Thanks for the reply herbp. Hoping for the best
Old 02-15-2013, 06:38 AM
CJ645Bern's Avatar
Did u put the cleaner in right before putting gas or did u drive for a little longer?
Old 02-15-2013, 07:19 AM
tampamark tampamark is offline
Mein Auto: 650 Sold - '12 Jaguar XK
Do you have a link to this? My store doesn't show that price darn it.
I am a Techron convert, my Motorcycle (CBR 1000RR) was running rough at initial start and was getting progressively worse. Ran some through the fuel and it smoothed out and ran perfect.
Same with my Jeep Wrangler, had some periodic misfire issues, one bottle of Techron and no further issues.
Old 02-15-2013, 07:54 AM
roseng's Avatar
roseng roseng is online now
Mein Auto: 2016 528i + 2007 650 Vert
I bought a case at Costco and I think it was about $3.00 a bottle.
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 02-15-2013, 07:56 AM
For that price I may start drinking it!
Old 02-15-2013, 08:04 PM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
Now that was funny, I think I will try it too my bowels are misfiring.
Sent Via iPhone using BimmerApp
Old 02-15-2013, 08:18 PM
CJ645Bern's Avatar
No oreillys near me. Spent 13 at napa :/
Old 02-15-2013, 09:04 PM
roseng's Avatar
Techron and Jack! I'm in.
Old 02-16-2013, 07:26 PM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
Or Techron and Coke!
Once a 6'er, always a 6'er.
Old 02-16-2013, 08:13 PM
I was just on their website yesterday, & the add was going across the top of the screen. My zip is 30907, if that makes a difference?
