Old 02-13-2013, 05:57 PM
jay-bird707 jay-bird707 is offline
Mein Auto: 1996 750il
NEED HELP! Fault Code P0740 ON A 96 750IL
So right when i take my car to the smog shop the deadly "check engine light" comes on and fails the test. The code is p0740 "torque converter circuit/open". After doing some research and getting opinions it seems like im gonna have to change or replace my torque converter. Is any positive that this is what needs to be done? If so, im pretty handy with cars and i am confident i can do the repair myself. Is there anyone out there that know a link of where i can get the steps of doing it myself?
Old 02-13-2013, 06:36 PM
BMWFatherFigure's Avatar
Old School
Bentley manual
Current:
E38 Parts Car
Previous:
Old 02-13-2013, 06:39 PM
Is this a book i can find at any parts store?
Old 02-16-2013, 08:27 PM
speedkingrc speedkingrc is offline
Mein Auto: 88 BMW 735i
look code up online or contact bmw dealer and ask a tech their
Old 02-17-2013, 06:34 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Post # 3 http://www.bimmerfest.com/forums/sho...rque+converter
JOY = BMW
Old 03-24-2014, 11:03 AM
FreeMW740IL FreeMW740IL is offline
DOTD
Mein Auto: 2001 BMW 740IL
Long story EXTREMELY short. 2001 740il Bought a used tranny that had nice fluid in it. installed it with the torque converter and new tc seal. filled it with VIN NUMBER MATCHED Febi Bilstien GERMAN ATF. first test drive was awesome. second test drive my torque converter was not locking up, and the SES light came on. Scanned it. 0740 code, went to the shop had them plug into the MEGA computer. Code was Gear Slip and TCC. he said most likely replace the torque converter due to the seal going bad internally. basically what happens is as the tranny sends fluid to the TC, it has to build up pressure to lock up. If that internal seal is blown, then all the pressure slips by and back into the tranny NEVER allowing the TC to lock up. Other theories Ive read are the solenoid, which seems to not be the fix in most cases, damaged valve body, low line pressure, and of course BAD TC. So, im going to spend another several hours researching before I pull the tranny back out (EASY) and install a rebuilt TC and new $15 input shaft seal.
HTML code is Off
