Old 02-13-2013, 10:19 PM
z10 z10 is offline
Mein Auto: 650i
35k miles...time for new brake rotors?
I have 6 days left on my warranty so,I took my 09 in today to have the brake pads changed before the warranty expires. The dealer changed all the pads and all of the rotors.
I bought this car used back in June with 28k miles. It's now driven mostly by my wife as her DD. If I need to drive something hard I drive my C6 Z06. So the 650 is not exactly driven hard.
What I want to know is changing rotors on all 4 corners normal at 35k miles?
Old 02-13-2013, 10:22 PM
mr29 mr29 is offline
Mein Auto: bmw
sounds right if they are runflats
Sent from my XT557 using Bimmer App
Old 02-13-2013, 10:27 PM
z10 z10 is offline
Mein Auto: 650i
What does running run flats have to do with brake rotors wearing out? I must be missing something?
Old 02-13-2013, 10:33 PM
Mein Auto: bmw
more so the brakes i meant was thinking of something else.35k sounds right probably shoulda been changed at 2 to 3 years old.i missed the part you said you got it with 28k on it.yea coulda been if the last owner drive it hard.ive found between 3 to 4 years your need new brakes on most cars and rotors if something odd happened or driven hard. i also ask to see stuff before its replaced
roseng's Avatar
roseng roseng is offline
Mein Auto: 2016 528i + 2007 650 Vert
Sounds like the dealer knew he could do the replacement and get paid. He made some extra $$$ and you got new rotors.
Does the work order say "Warped" or anything like that?
I Love LA. It lets me ride in the winter with the top down.
07' E64/Black....14' F10/M-Sport White
Old 02-13-2013, 10:38 PM
z10 z10 is offline
Mein Auto: 650i
Quote from Invoice:
"Replaced front and rear bake pads, rotors, and sensors. Frt pads at 3mm, rear pads at 3mm. Frt rotors at 22.3mm and rear rotors at 28.1mm."
Seems strange that the front and rear pads would be at 3mm all the way around. My experience tells me that fronts wear faster than rears.
Understand I'm not complaining, I'm just trying to find out if I need to expect the same thing at 70k miles?
Old 02-13-2013, 10:40 PM
Mein Auto: bmw
Quote from Invoice:
every 3 to 4 years id have them replaced based on miles and wear .i would say yes seems accurate at 70k
Old 02-13-2013, 11:03 PM
z10 z10 is offline
Mein Auto: 650i
So are you saying 35k is normal? Or...70k?
Old 02-13-2013, 11:04 PM
Mein Auto: bmw
35k is normal for brakes. rotors shouldn't be that beat up unless it was driven hard
Old 02-13-2013, 11:12 PM
z10 z10 is offline
Mein Auto: 650i
Wow!!! what are these things made out of?......... That's horrible for a non tracked car. My C6 has 30k on it and it's no where near needing rotors, and it's not exactly a commuter car.
I smell BMW tax.
Old 02-13-2013, 11:19 PM
Mein Auto: bmw
I'd be looking at the brakes they just put on to ensure they aren't cheap ones that will fail early. at 70 k you should need new brakes but not rotors
Old 02-13-2013, 11:30 PM
Yorgi's Avatar
Yorgi Yorgi is offline
35K is probably normal for rotor life. The car has 360HP and weighs 4,200lb. You will go through a lot of pads and tires if you drive even moderately hard.
3mm is the min thickness for pads and I typically do not let my pads get that low. Pads are 12mm thick when new. You were probably on your second set of pads in the front and on the original pads at the rear. Rears tend to wear at about half the rate as the fronts.
The front rotors were way below the min thickness which is 28.4mm. Rotors typically last for 2 sets of pads.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 02-14-2013, 06:01 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
I did rotors and pads around 55k because I wanted to know exactly what I had on my car and how old it was. I didn't even bothering to measure. New is new.
BTW - What is a C6?
'07 650i Coupe - Black Sapphire Metallic
M6 bumpers, skirts & wheels
BMW M Cross Spoke Composite 101 Rims 20"
HUD, Comfort Access
Old 02-14-2013, 06:33 AM
daytona745 daytona745 is offline
Mein Auto: 645CI, CorvetteZ06
I have to agree with you Z10. I have a C6 Z06 also and it is much more dependable than my 6 series but I still love driving it, especially since the top goes down.
Old 02-14-2013, 06:46 AM
gregb's Avatar
gregb gregb is offline
Mein Auto: 2014 BMW ///M6 vert
Thanks for clarifying and adding helpful information to this thread!!
Regards, Greg
'14 M6 vert, san marino blue on amaro brown full merino leather, drivers' assistance, exec package, B&O sound system, CCB package, akra exhaust, tint, windscreen, etc.
'07 650i vert, beige/jet black, sports & cold weather pkgs, comfort access, etc.
'11 Acura MDX Advance with Entertainment pkg for wife - no mod's '04 Acura TSX (daughter) and '12 VW GTI - Autobahn (son)
Old 02-14-2013, 10:44 AM
z10 z10 is offline
Mein Auto: 650i
BTW - What is a C6?[/QUOTE]
6th Generation Corvette. Z06=505hp.
Old 02-14-2013, 10:46 AM
z10 z10 is offline
Mein Auto: 650i
[QUOTE=Yorgi;7380399]35K is probably normal for rotor life. The car has 360HP and weighs 4,200lb. You will go through a lot of pads and tires if you drive even moderately hard.
So what your saying is the car is underpowered and over weight?
Just messin with you. Thanks for the info.
Old 02-14-2013, 11:30 AM
07 E63650i's Avatar
07 E63650i 07 E63650i is offline
Freude am Fahren
Mein Auto: BMW E63 650i
BTW - What is a C6?
[/QUOTE]
Sweet Z06!
Once a 6'er, always a 6'er.
Old 02-14-2013, 12:04 PM
Yorgi's Avatar
double post
Old 02-14-2013, 12:05 PM
Yorgi's Avatar
Yes, very overweight. I'd say enough power for a GT.
Love the Z06, drove one on the track a few years ago. The grin it put on my face lasted a few days. My next track car will be a Z06 or a GT3.
'04 M3 - track
Old 02-14-2013, 12:13 PM
z10 z10 is offline
Mein Auto: 650i
05
I've enjoyed them both. But I always seem to gravitate to the Z06. I've owned the car for about 3.5 years and put about 27k miles on it in that time. It's been absolutely rock solid with zero problems. Something about 505hp and 485ftlb of torque that are adicting.
Oh, and it returns about 28mpg on the highway. It's our "Economy Car"
Old 02-14-2013, 12:54 PM
I didn't have a GT3 but I had a 911 Carrera 2. No comparison between that car and the Z06. The GT3 is a lot different than the Carrera 2 though. You think maintenance on a 6 series is high, try the Porsche and you'll wish you had the BMW back.
Old 02-18-2013, 01:10 AM
07 E63650i's Avatar
Freude am Fahren
The Porsche must be that expensive to own? I was about to think that it was only BMW or Mercedes.
Old 02-18-2013, 01:12 AM
07 E63650i's Avatar
Freude am Fahren
05
Honestly, I was never a big fan of Vettes, but the C6 Z06 changed it all for me. A dream car for the track enthusiast. You are lucky to have one!
Old 02-18-2013, 01:22 AM
Nitrogen's Avatar
Nitrogen Nitrogen is offline
Mein Auto: BMW 650i Convertible
That's it all of you stop this is a 6er forum . Stop wanting the Z06. It's a great racer but we are die hard 6er people.
I think ....Man that Z06 looks sick. I think I want ...... never mind I am getting sucked into the black hole as well .....no.......no....I ...will .....not give in .....
Sent Via iPhone using BimmerApp
