E36 (1991 - 1999)
Old 01-21-2015, 12:42 PM
stuartgto stuartgto is offline
Mein Auto: 318ti, 335i
Another failed CA smog test
OK, I'm next. 1995 318ti/184K miles
1st smog test
/////////// 15mph // 25mph
RPM ////// 1896 // 2078
%CO2 (mea) 16.4 // 16.2
%O2 (mea) 0.0 // 0.0
HC (max) 85 // 35
HC (mea) 84 // 85 FAIL
CO (max) 0.34 // 0.33
CO (mea) 0.18 // 0.18
NO (max) 486 // 502
NO (mea) 409 // 244
So unfortunately, I have to go to a STAR station to get a smog. 2nd smog test after changing the oil, air filter and the spark plugs, with the car being run hard prior to the test. Incidentally, the tech told me that it is illegal to have the car run hard and HOT prior to the test. But I did anyway.
2nd smog test
RPM ////// 1900 // 2280
%CO2 (mea) 11.5 // 11.4
%O2 (mea) 5.8 // 5.8
HC (max) 85 // 35
HC (mea) 68 // 45 FAIL (Lower)
CO (mea) 0.09 // 0.10
NO (max) 486 // 502
NO (mea) 154 // 60
O2 sensor at 135K mi, 2010
How does one tell if the catalytic converter needs to be replaced?
Any and all help is appreciated. Thanks in advance
Old 01-21-2015, 03:22 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
well your second readings are way worse than your first....
the efficiency numbers (co2) are down compared to the first, and the o2 jumped way up from the first test.
there are ways to check the cat, but will require you to go to a repair shop with a gas analyzer.
the car does not have an egr system, so the cat reduces nox. when hc and co are at their "best" readings, nox is usually at its highest point.
if you are not having any sort of drivability issue and the maintenances are where they need to be, then you could very well likely be looking at a cat. however, since cali is one of those states where they are ubber strict on this sort of thing, your options are limited and therefore, pricey.
df
Old 02-18-2015, 09:12 PM
So after cleaning the MAF sensor and the throttle body with CRC products and adding AMSOIL PI Performance Improver Concentrate to the gas twice, the readings now are:
3rd smog test
RPM ////// 1944 // 2088
%CO2 (mea) 14.7 // 14.8
%O2 (mea) 0.1 // 0.0
HC (max) 85 // 35
HC (mea) 159 // 35 FAIL at 15 MPH
CO (mea) 0.36 // 0.10 FAIL at 15 MPH
NO (max) 486 // 502
NO (mea) 1068 // 116 FAIL at 15 MPH
I was all ready to get a cat and the muffler shop recommended the AMSOIL PI concentrate. At the test today, the technician wondered if the product should still be in the tank. I still had 1/2 tank full from my second tank of gas with it. Did it make the cat expire or do I need to run the additive out of the tank prior to testing?
Old 02-18-2015, 10:05 PM
u3b3rg33k u3b3rg33k is offline
Mein Auto: e30, e60, R1100S
ditch the performance enhancers, and put a bunch of ISO-HEET into a fresh tank of gas and try again. or just mix it up to E20 and try again. same thing.
e30: '87 325i: MAF+WAR chip, long tube STAHL headers, 5MT swap, 4.27 torsen
e60: '08 550i M-sport, 6MT, ARC, Active Steering, 19" wheel delete
R1100S - oilhead FTW
Originally Posted by MeNoo View Post
Although I have nothing scientific to say, I can confidently say that it works.
Originally Posted by Burning2nd View Post
If you want to use the fuhrers snowmobile you gotta have das tires
Old 02-19-2015, 04:53 AM
with all that you have done, you could be looking at one of 2 possibilities, both of which are gonna be $$$
the first would be the vanos bleeding down. for whatever reason, higher nox readings are an indication that the vanos is on its way out. at least this is what i seem to have seen as a consistent cause across the board.
the second is the cat.
it could also be both. however, as i stated before, you could guess and hope to fix it, or, you could take it to a repair shop that can test the cat for you and confirm it is not functioning properly.
df
Old 03-07-2015, 04:24 PM
Well, after all is said and done, a new catalytic converter was the answer. Thanks for all the help.
Old 03-07-2015, 05:07 PM
glad to hear it. did you just have it replaced, or did you get it checked first??
what were the new readings that you passed with??
df
Old 03-08-2015, 11:59 AM
I did have it checked first. A mechanic used an IR temperature gun and the reading before and after the CC was barely less than 100 degrees. It is supposed to be at least 175, and mine was no where near that delta. The final readings were:
4th smog test
RPM ////// 1858 // 2108
%CO2 (mea) 14.9 // 14.9
%O2 (mea) 0.0 // 0.1
HC (max) 85 // 35
HC (mea) 79 // 19
CO (mea) 0.10 // 0.00
NO (max) 486 // 502
NO (mea) 78 // 9
Old 03-08-2015, 12:20 PM
bliger7gz's Avatar
bliger7gz bliger7gz is offline
Mein Auto: 1994 BMW 325is
Was the replacement cat a used one or a brand new one.
1994 BMW 325is "Feldt" w/Turner Motorsports chip
Old 03-08-2015, 12:42 PM
eeesh,...hc is *real* close...and while i understand the idea of using a temp reading of a cat, but it is not exactly something that was considered to be accurate. that is why using a gas analyzer is the only way to confirm the efficiency of the cat.
that being said, you passed, but i would still suggest performing some additional things like run some seafoam through the engine.
a new o2 sensor with a new cat is also something i strongly suggest.
df
Old 03-08-2015, 05:04 PM
The replacement cat was new. Magnaflow 332004. When I had the cat checked, the mechanic didn't have a gas analyzer. I will look into replacing the O2 sensor. It was new in 2010, 50K miles ago.
Old 03-09-2015, 11:39 PM
E36Ken's Avatar
E36Ken E36Ken is offline
E36 addict since 1992
Mein Auto: 1993 325i
One most overlooked cheap practice before the sniffer test is to do an oil change. Carbon deposit (amongst many things) in old oil can alter the readings of the tests. Or so I was told by a smog tech.
Old 03-29-2015, 02:35 PM
Magna_Flow Magna_Flow is offline
Past Sponsor
Mein Auto: BMW M3
We're glad to hear the cat solved your problem. The smog tests here in California are brutal. That said, there are a lot of things you can do to prolong the life of your cat. One thing to be aware of is that running a high-zinc oil like a diesel oil (Rotella, Delo, etc) which many people do in their older performance cars, can kill a cat. Also, unburned fuel is a good way to kill the cat. If your car burns coolant or oil at all, they can dramatically shorten the life as well.
Definitely replace your O2 sensor, make sure everything is good and tuned up, and if you have any of the previously mentioned issues make sure and sort them out. Do that and your new cat should outlive the car.
Cheers!
