Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 02-15-2013, 07:58 AM
JMLHK JMLHK is offline
Mein Auto: BMW 740il
Squealing Brakes after 24000K of normal driving
The right rear brake oin a 15 month old 740il with 24000K squeals when brake pedal is pressed lightly. The sound stops when the pedal is fully depressed. The dealer tested the car for a few days, and then said the brake light had come on and the car now needs new brake pads! Is this possible after only driving the equivalent of 15,000 miles in normal driving conditions? It seems like a very short time for the brake pads to wear out. Any suggestions/advice will be very much appreciated.
Surprised in Hong Kong
Old 02-15-2013, 08:31 PM
Popoemt Popoemt is offline
Mein Auto: 2013 740 Li
Any chance they will replace for you at $0 cost(not sure if HK has the maintenance program built in?) V/r, Tim
2013 740 Li
2007 G35 (trade-in)
2003 Z06 (Black, 50th Anniversary)
2001 Z06 (Torch Red)
Old 02-18-2013, 03:27 AM
They don't appear to receptive to that idea. It's a free market economy, but nothing is free.
Old 02-18-2013, 10:56 AM
I'd argue it's abnormal wear and tear (I could swear I just saw something on the BMWUSA site that mentioned the long lasting brakes?) I think it was under the 740 overview section where it mentions safety/driving etc, V/r, Tim
With the idea being you are driving "normally" and not mashing the breaks every day all the time....
2013 740 Li
2007 G35 (trade-in)
Old 02-18-2013, 11:38 AM
rdorman rdorman is offline
Mein Auto: 2000 imola red 740i Sport
15k miles is very low. Most likely they will find a sticking caliper (guides, piston, etc). If you can see them then look and see if the right rear is about the same thickness as the left rear. On your car, the rear sensor is on the right.
Old 02-18-2013, 05:15 PM
Thanks for both of these recent replies. I'll see how it goes, the case continues . . .
brake pad replacement, brake pads
