Old 02-15-2013, 10:28 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
How to remove the two kidney grills (mirror trick?) when the hood just won't open?
Based on this information from Michel, I open this thread to ask how to remove and replace the kidney grills when the hood can't be opened, especially if you have pictures of the reputed "mirror trick":
> E39 (1997 - 2003) > Hood won't open
Originally Posted by mjbennett9 View Post
Thanks bluebee. I've gone to all of those links already--nothing. What is needed (for others in the future) is a less destructive way of removing the kidney grill (like I had to do).
I wouldn't share the technique as no one wants to literally rip theirs out like I did, but it was the only way.
Also, I just tried the mirror trick, but without knowing what I'm looking for (no pics), it's hard
to stick a home made contraption/pick in there without knowing what I'm aiming for. I did see what I think is the two cable connecting together (one shiny, other rusty), but no plastic housing around it. if it is literally the tiny connection between the cables, it won't budge. Shoved a screwdriver in there too. but again, not sure what I'm even poking at. Most posts just talk about shoving a hand / thumb and feeling around--which I've done.
I'm able to duplicate popping open the passenger side of the hood no problem just by yanking on the cable 1/2" from the driver's side kidney grill opening. However, no movement on the driver's side. So if nothing else, yanking on the cable does yield some result (opens one side). I do think this is an easily repeatable step for others too. What is more difficult for me, and soujnds like others, is an easily repeatable task to open the driver's side. :-)
Old 02-15-2013, 10:30 AM
bluebee's Avatar
Here's what I wrote in the referenced hood-release thread, before I started this DIY thread, so that we'll have a spot in the bestlinks for the NEXT person who asks the same question.
What we need is more information about the mirror trick and how to remove the grills when the hood won't open ... without destroying them in the situation Michel experienced today.
What is needed ...is a less destructive way of removing the kidney grill
I typed /kidney and /grill into the bestlinks and that came up blank.
An advanced E39-only title-only search for the same keywords came up with these, but I don't know if they have the information you want for us and others:
I scrolled through each of those threads, most of which were lackluster discussions all about looks (and not much of substance) - but one referenced this DIY of sorts:
- M5 grill installation photos
Old 02-15-2013, 10:43 AM
MJB9 MJB9 is offline
Mein Auto: 2002 525i (E39)
Thanks Bluebee. I tried several of those already and a few that I hadn't seen, I tried now too. The first one goes to someone asking a question, the others just cover install more than anything. But overall, they assume you already have access to an open hood. :-) I ended up using brute force, but there has to be an easy way for those without access to an open hood. :-) I could do easily if the hood was open.
I'm guessing it would be a 5 second job to remove grills if the hood was open. :-)
For me, I'm passed that point now and just need to get driver's side of hood open. I saw your pic you just posted and #23 (to left of it, is about as best I can figure out that I am seeing from within the grill, with the mirror. and there is no room to see, even with a mirror, passed that point. I mangled an attempt at the paint roller pick, but do not think I'll get it anywhere but will try.
Old 02-15-2013, 10:52 AM
after another look, I think the closest photo is from spoila (attached). it didn't make sense to me at first, because I thought this was taken from the top of the car, but after looking closer, it was taking from under the car and in through the driver's kidney grill. Also, adding to the confusion for me, was that both my holes are full because my cables are still there.
Break must be somewhere else. So I don't think the pick will work because there's nothing to stick the pick into. I'll try shoving it in and moving things around, but after reading all the descriptions of where they join, I think using and adjective of "housing" is not a fair assessment of what we are looking for/at. the attached pic is probably best one I've seen so far. I just need to figure out how to move it with both holes filled wiht cables.
Name:	Hood release cable came lose.jpg
Old 02-15-2013, 11:41 AM
bluebee's Avatar
I just realized, rather embarrassingly, that that was the fundamental problem, and, that, for some reason, all the bowden-cable-release tricks in the bestlinks didn't work for you.
- How to maintain (1) and repair your hood release bowden cable (1) (2) (3) & how to replace the hood cable the easy way (1) & how to open the hood when the hood cable snaps (1) (2) & how to open the hood manually when you have a dead 12v car battery (1) [or trunk (1) (2)].
So, I just now belatedly updated the title to indicate the problem is how to remove the kidney grills when the hood won't open.
For me, I'm passed that point now and just need to get driver's side of hood open. I saw your pic you just posted and #23 (to left of it, is about as best I can figure out that I am seeing from within the grill, with the mirror. and there is no room to see, even with a mirror, passed that point. .
For reference, since these are essentially public conversations, here is the pic (I think it's from cn90's DIY) that he's referencing for part #23:
after another look, I think the closest photo is from spoila.
Do you need one of us to snap a specific picture of a specific area under the hood for you to visualize the mechanism?
Old 02-18-2013, 11:25 AM
bluebee's Avatar
I just noticed this hood release tool from this thread:
- > E39 (1997 - 2003) > E39 Hood Release Broken, how do I release?
Old 03-02-2015, 01:21 PM
danzee danzee is offline
BMW CCCA since 1986
Mein Auto: E34, E39, E46
Can't budge the lever
I see that mechanism and can feel it and I can even get a tool on it. However, I can't budge it at all. I don't how to get any penetrant on it either because of it's position. Am I missing something? I'm pushing towards the driver's fender on the piece that holds the two cables. Help!
Old 03-04-2015, 08:09 PM
monkeyman_69 monkeyman_69 is offline
Mein Auto: E39 528i
I feel your pain. I've had to pop my hood twice by going thru grills. One time the barrel end of a bowden cable came out of the 'box' mounted to the latch above the grill frame. Another time the 2 bowden cables that couple in a little plastic junction box in the engine compartment by the fender were messed up. The junction box was snapped closed, but one cable was popping out and riding above the other, so nothing happened on the hood latches.
Some advice up front. Once you get your hood open, take off the driver's side kidney. Then dink around, test your work, latch and unlatch the hood a few times. And if you did it wrong or it breaks again, at least you have access. Replace the grill when you know all is well.
I can't tell you how to get a grill off when the hood is closed. Working all the clips even w/ the hood open is a PITA. Good luck.
Back to your original question. If you kneel in front of the bumper and look upward thru the drivers side grill, you'll see the square 'box' that will have the barrels of 2 bowden cables set in there. It's just a slot/tab feature, nothing fancy. Working thru the grill hole, I've tried mirrors, long screwdrivers, etc. I even tried a helper, but 3 hands don't fit. Ultimately if you angle a small makeup mirror just right (keep it directly below the 'box' so it's resting against the plastic ribs guarding the fan, use a 90 deg pick. Jam the tip against the bowden junction you see, and push. That will mimic the act of pulling from inside. It's not easy, takes more force than you'd expect, and you can break the tab you are pushing on, which makes opening the hood more difficult, but replacing the little box is easy and fairly cheap.
Also, keep your push pick horizontal as best you can. That means the shaft should be up against the top of the kidney opening, not down low, like its resting on the bumper.
I can't take a picture now, but may be able to tomorrow.
Old 03-04-2015, 09:07 PM
Sroor9001 Sroor9001 is offline
ALGhoul
Mein Auto: Bmw 525i 2002
I don't know but I've change mine long back with black and removed mine chrome easily
Case brackets clips was broken and it was silicon glued damn seller
But still that black not fitting well mean I have to move it little to raise bonnet lever these where
China kidney grill that's why
