Old 02-15-2013, 12:04 PM
HneDog HneDog is offline
Mein Auto: 1998 740il & 2010 750li
bmw e38 subwoofer build help
so all my e38 stock woofers in the back are blown and rattle bad. i am replacing them but im not quite sure how to do it.
http://www.ebay.com/itm/130848142704...=p5197.c0.m619
could i make this happen? i dont need 2 subwoofers ive been in friends cars with similar subs i just want to be able to hear and feel the bass. will the amp and everything be compatible with my 1998 740il? im getting a new battery as well any suggestions on that?
any help would be greatly appreciated guys thanks.
Old 02-15-2013, 09:43 PM
BMW 3-SERIES BMW 3-SERIES is offline
Mein Auto: 2000 540i Sport (E39)
There is a write up on E38.org, I can snap some pics of my setup. I didn't know how to set it up but honestly it was easy. You could also have an audio shop do it for cheap. That eBay listing is good. All you need is some bass, not crazy amounts that can be heard down the street.
** Removed **
Old 02-16-2013, 09:21 PM
speedkingrc speedkingrc is offline
Mein Auto: 88 BMW 735i
its not hard man. i mite be keeping factory amp and but im changing the head unit to a double din... ebay became my close friend when i was looking for the metra dash kit for my car and the wiring harness
Old 02-18-2013, 10:00 AM
Koolkidd89 Koolkidd89 is offline
Send a message via AIM to Koolkidd89
Mein Auto: 1997 BMW 740IL
How did you make out with changing the subs? I have some other issues i have to resolve with my '97 740iL, but i know my rear 5" subs are blown and i NEED to get those out of there when i'm done with the repairs on my Vehicle. The only difference is, I dont mind HAVING bass that can be heard when i'm at the beginning of my block. any suggestions, and if possible could you take pictures and document your steps (or at least post a link to the e38.org URL showing the same procedure). Thanks
Old 02-18-2013, 11:55 AM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
Have you thought of using the OEM enclosure with aftermarket subs? Ive got a pretty big setup but If I were to go that route, I would cut the top of the OEM box and make a new face with two 6x10 subs... The install would be hella clean
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato (SOLD)
BMWE65: 22x10 / 22x11 Asanti ELT (SOLD)
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS430 UL:Air Suspension, 20"MAYA DLS
Old 02-18-2013, 12:40 PM
^yea man i wanted to just use the oem sub deck but i feel like it would be easier to just put the single 12 inch in the trunk near the amp and everything. i was wondering this would give a good kick ( Kicker C12 12" Subwoofer Single 4 Ohm 150 Watts ) cuz this is my first sub install because mine are completely blown.
Old 02-18-2013, 12:41 PM
Yea man ill take pictures and tell ya about my trial and error. my buddy who does this stuff all the time is gunu help me so it should be a clean install.
Old 02-18-2013, 12:46 PM
u install it yourself? yea that would be cool if u posted some pics but could i just replace the stock amp ( or could i use it that would be sick ) or do i have 2 amps in although i dont want to have to do that i just want it clean with a sub in the far back of my trunk.
Old 02-18-2013, 12:57 PM
SideShow activist
Mein Auto: 745Li
<---GIRL
Yes, the single 12 would be easier and would provide the kick youre looking for with ease The use of the OEM enclosure is just sumthing I thought of that would be hella cool.
my personal setup is 2 Alpine TypeR 15's and many amps....also have replaced many alternators
also, heres probably the best tutorial ive seen on E38 sub installs:
http://7social.org/social/index.php/...ll-on-a-budget
Current Lineup:
Old 02-19-2013, 01:16 PM
y u got many amps? and would the stock amp be good enough to power my sub at 200 watts? it says its 150 watt rms ( which i dont rely kno what that means im a noob sorry ) and max output of 300 watts.
Old 02-19-2013, 01:41 PM
nvm did the research found ut what that means lol. but can someone plese help me on how to wire that setup i posted up top. i dont want to F anything up first try and i have no idea what "channels" and stuff means. i wish it was just as simple as hook the wires into the sub and the amp and thats all that needs to be done.
Old 02-19-2013, 03:15 PM
SideShow activist
Mein Auto: 745Li
ive swapped out the entire OEM system...running two Alpine Type R 15's , type X interior speakers,etc,etc
That link i posted goes step by step installing the same stuff u posted.... even shows what tools u need
Current Lineup:
Old 02-19-2013, 03:38 PM
yea just made an account to check that out. thanks this helps me a buch hopefully i can get the job done without messin everything up haha
Old 02-19-2013, 03:59 PM
i dont have nav so that good but i think i gada buy the 26 pin to 5 pin converter and the whole splicing thing gunu kill me or my car haha
Old 05-21-2013, 12:06 PM
beemerMike317 beemerMike317 is offline
Mein Auto: 95 740IL
I was changing my head unit, bought the wiring harness and no sound to the speakers. I was told I have to hardwire the doors because the factory system amy can't be bypassed uding the new head unit you can't connect the speaker wires to the harness. Now I can't get through the door jams to pass wires through the rubber loom. Help
Mein Auto: 95 740IL
replaced head unit but now no sound
HTML code is Off
