Old 05-03-2013, 08:42 PM
chansta chansta is offline
Learning Daily
Mein Auto: 89 CIVIC
Originally Posted by CALWATERBOY View Post
Consensus seems to be: Plan on it at or about 60k mi.
But, is the problem PCV blowby alone? In that case, DANGER! ILLEGAL! disconnecting the PCV system from the intake should solve the issue.
That's done by virtually nobody on public roads. Also, I'm astonished that nobody's come up with a way to allow PCV and fully filter/wash air coming through.
You automotive lubricant chemists - what's so hard?
Come to think of it, I know where we might get a well qualified answer - I'll post next week if it develops.
crank case ventilation has nothing to do with this issue. thing with direct injection is, there is no fuel to clean up the intake valve which results in carbon build up. carbon tends to absorb/release fuel which results in misfiring especially in cold start conditions.
iATN
Old 05-04-2013, 03:21 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
However, without the PCV recirc, it's difficult to envision a source of carbon for the buildup.
Old 05-04-2013, 03:36 AM
kmorgan_260 kmorgan_260 is offline
Mein Auto: 1997 528i
Originally Posted by ramblinman View Post
GM and Ford don't have the carbon build up problems that plague BMW DI engines. Here's why, "Haider, GM's V6 assistant chief engineer, explained how GM has designed its DI engines to combat carbon buildup: "We maintain great engine function and performance in our all our DI engines through an optimization strategy with our valve events," he said. "Our intake-cam timing, injector targeting and timing of the injection events are optimized to avoid direct fuel contact on the intake valves. This strategy keeps smoke and soot formation to an absolute minimum, which in turn prevents excessive deposit formation." BMW's N54 engine wasn't ready for prime time. Mike Miler the tech guru at the BMW Car Club says the N54 was a beta test of technologies. Eventually BMW will get this right. For all of us who bought N54 engines, it's going to be one problem after another as the production cars get older. My wife's minivan is 9 years old and has 120,000 miles and the tail pipe doesn't have a trace of soot. My BMW 2008 335 with 35k miles has dual exhaust tips covered in soot, some of which gets deposited on the intake ports and valves. The N54 is a dog. But BMW won't admit it made any mistakes. They never stand behind their engineering when the warranty runs out.
What about the N55? Did BMW fix the problem on it?
Consequently my N54 is at 98K and still pulls like a train although I have started to notice an occasional rough idle. Guess I will move the walnut blast higher up the to-do list.
94 318I (Daughter's car), 96 740IL(current project), 97 528I(DD), 07 335I(Son's car)
Old 05-04-2013, 04:02 AM
johnc_22's Avatar
johnc_22 johnc_22 is offline
Squeal like a BMW
Mein Auto: 2013 Audi A4
I had this done at about 70K when the dealer had the car for wastegate and other warranty work. It pulls much stronger at low RPM's and got rid of terrible stumbling in 5th and 6th when accelerating hard on the interstate though I think this was more an issue of maladjusted wastegates. Not sure what I'll replace the N54 with - not sure BMW has the reliability thing down yet.
2013 Audi A4 - Premium+/Sport/MMI/B+O Audio
2007 BMW E90 335i (retired)
Old 05-04-2013, 08:36 AM
Verts4Ever's Avatar
Verts4Ever Verts4Ever is offline
Random Helpbot
Mein Auto: 2011 E93 335i
Originally Posted by thekurgan View Post
Looking at these posts reminds me I'm glad the N54 is gone.
The N55 isn't much better... I have an oil catch can on ours, and it's amazing how much it collects even with our low mileage.
Old 05-04-2013, 08:58 AM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
It is the issue. Vapors and small ammt's o'liquid phase create the buildup.
If disabled, prob disappears.
Old 05-04-2013, 04:14 PM
But here's the rub: How much of that is condensation?
Old 05-04-2013, 08:58 PM
Learning Daily
Mein Auto: 89 CIVIC
It won't disappear. Valve overlap is the main contributor
Let me correct myself. Im not saying crank case ventilation isn't a source I was just stating that fuel not being there to clean up the valve is the reason why
iATN
Old 05-04-2013, 10:00 PM
Backpedalin' fast!
May be right re: BMW - some chatter about GM having solved that issue.
Old 05-04-2013, 10:09 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
Nice thing about....smart use....of valve overlap is that it can help make for better power. It's all a balancing act, I guess.
The big takeaway for me: I should invest in getting the remainder of the equipment to do a home-brew valve cleaning. The big PITA for me is the means to precisely turn the engine as needed.
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 05-20-2013, 09:25 PM
galahad05's Avatar
Better with Butter
Okay, I've had my new oil catch can on my car for about 500 miles now.
I had to go back in and tighten the bracket holding it in place, so since I was already there....I took a look to see what it caught.
Nothing.
Literally no visible residue.
-- Irish Proverb
Old 05-20-2013, 09:34 PM
Leekay07 Leekay07 is offline
Mein Auto: X5 35D, Former X1 and 335
The oil that we get on the valves is a vapour. Not a liquid heavy enought to drop off over a small void.
If you like customer service. Don't look beyond a BMW.
Old 05-20-2013, 11:08 PM
galahad05's Avatar
Better with Butter
The can has been shown to condense and capture at least some of the oil returning via the PCV system--I've seen users' pictures.
It's just that I haven't seen any in mine yet.
BMW has a cyclonic oil condensate separator system that, at least to my eyes, seems to be doing a pretty good job, based on what I'm seeing on my car.
I'm supposed to check and dispose of the oil in the catch can every 1-3 months. Or for my driving: 1k to 3k miles.
-- Irish Proverb
Old 01-10-2015, 04:45 PM
Road&MTN_Biker Road&MTN_Biker is offline
Mein Auto: 428; 228, 440 on order
Do you think using 89 vs 91 makes a difference in the carbon build up?
Thanks,
Originally Posted by bmwoem1 View Post
The sad thing is, those intake valves aren't even that bad... I've seen way worse (I'm a BMW master tech). The N63 engines are just as bad, I'm even starting to see the same issue on the N55's... We've had this problem on all direct injection engines starting with the N73. The buildup is noticeable as early as 20k miles
Fun Car: 2015 228i Sport Deep Sea Blue, CR with Track Pack, Premium Pack, Xenon, ZF tranny, real tires and other goodies.
Road Car: 2014, 428iX Coupe, About to be replaced with Tanzanite blue/ golden brown / Red sycamore 440 GC with track pack and most options. Delivery late December.
Old 01-10-2015, 05:33 PM
Zooks527's Avatar
Thanks,
No, Nothing but 93 Octane Shell in mine, and they were caked up. The DI system doesn't let any gasoline (with associated cleaners) flow over the intake valves, and the PCV recycle cokes on.
Old 01-14-2015, 10:30 PM
slenser slenser is offline
Mein Auto: 10 535i M Sport
I'm at 120k and I don't know if it has ever been walnut blasted. Has anyone ever tried Seafoam? Many swear by it in other car communities.
Old 01-15-2015, 03:05 AM
Zooks527's Avatar
There are some videos on YouTube. No one here on the board has admitted trying it that I have seen.
Old 01-15-2015, 03:57 AM
Banned
Mein Auto: 2007-335 HTC
Originally Posted by SuperTerp View Post
No problem! Yeah same... 6 bottles of techron at 3k intervals didn't do squat.
people need to realize that Techron is to clean the fuel system, keep the injectors clean
not the intake areas
Old 06-10-2015, 05:31 AM
Hookster57's Avatar
Hookster57 Hookster57 is offline
Mein Auto: 435i Grand Coupe
So is this problem still occurring on the new (2015) engines or have they fixed the direct injection issue?
Old 06-10-2015, 06:01 AM
BashedBarrique's Avatar
BashedBarrique BashedBarrique is offline
Mein Auto: 2006 325i
I know you posted this two years ago CAL. Did you ever post the follow up?
Seems to me that an old school breather tapped into the valve cover would (illegally) solve the issue. I agree with you that a system to filter the oil vapors shouldn't be rocket science.
Old 06-10-2015, 06:25 AM
07335's Avatar
07335 07335 is offline
Mein Auto: 2011 335is CAB w/DCT
So, yes, it's clean. How does it drive now? Looking at these posts reminds me I'm glad the N54 is gone. Reminds me of the RS4 nightmares with carbon build up.
Did they solve this with the newer DI engines? I think you need a hybrid DI and traditional FI design.
Old 06-10-2015, 06:51 AM
DSXMachina's Avatar
Bimmerdex 7.4!
It's beyond rocket science. Cars are among the most technologically complex yet reliable devices on the planet. The computational abilities far exceed the ability of rockets 10 years ago.
If you disconnect the PCV valve, or leave a breather tube out of most modern engines, they will stall at idle or run extremely rough. Such is the delicate balance of internal and external pressures which the computer relies on to minimize emissions and maximize efficiency.There are engines which will run extremely rough if just the oil dipstick tube is not fully seated! I sometimes wonder if that's part of the reason for switching to electronic oil level measuring.
It gets harder and harder all the time to tinker with engines.
Old 06-10-2015, 07:01 AM
wilt wilt is offline
Mein Auto: 2011 328i
Breather?! Gawd, BMW vaccuum leaks causing engine-start failures have been known for decades! My girlfriend at the time had an early 80s E30 that would not start one day, she calls me up because she needs to be someone at a certain time. I drive over, try to start the car to try to diagnose if it is fuel delivery or electrical, see the symptoms and pop the hood, press the dipstick firmly into the tube so its rubber plug seals, and try again...it starts, I'm a hero.
Old 06-10-2015, 07:32 AM
Biggiefl's Avatar
Biggiefl Biggiefl is offline
Mein Auto: 2008 335I Con
Was talking to a mechanic friend briefly on Sunday and it is a problem on most DFI cars. He read about using seafoam spray or equiv. closing valves and letting fluid soak on for hours or overnight and then do it again after a hard run to wash it off. I have used seafoam and Berryman's B12 as a concentrate in outboards to remove carbon. I would put a whole can mixed with another can of gas(about a qt total) and stick the gasline in it and run it at high idle or more until it emptied jar but engine still had fuel. Would shut down and let sit overnight and then run it on straight fuel. I have unstuck rings and the crap that came out of my prop exhaust looked like I ingested a large double fudge brownie and passed it through the exhaust. You can do it, just gotta figue out how and at what point is it too late. I just turned 18k on my 08 and am curious.
My garage: 2014 Jeep Grand Cherokee diesel, 2008 335i Convert., 1987 Mercedes 560SL, 1980 Corvette(highly modified), 2000 Harley Deuce, 1996 Suzuki DR350, 1985 Honda ATC 250SX, 1994 Donzi classic 22, 1981 Boston Whaler 13 sport...yes I need a bigger garage.
Old 06-10-2015, 07:44 AM
Hookster57's Avatar
Too late how?
