E30 (1982 - 1993)
Old 02-15-2013, 06:55 PM
steezysloth steezysloth is offline
Mein Auto: 2000 323ci
Exclamation E30 No Spark ): HELP
Hey everyone, i have a 89 325is 5spd
But i am not getting spark!!!
New thermostat and housing
All new hoses and gas lines
New main relay
New fuses
New coolant sensors/switches
New flame thrower ignition coil
New battery...
But i get no spark to the ignition coil
Here is a video i made to help you understand -
PLEASE HELP!!
_________________
1989 325is
Old 02-15-2013, 09:12 PM
t2112 t2112 is offline
Mein Auto: 330 ci / 325e in progress
Crank position sensor good and/or plugged in.
Old 02-15-2013, 09:22 PM
Yeah its brand new and plugged in right, any reason why my coil wouldnt be getting power?
Old 02-15-2013, 09:56 PM
Maybe the immobilize? It was parkedfor 5 years and the radio is locked
Old 02-16-2013, 02:32 PM
downhiller's Avatar
livin large
the cps gapped correctly? even though the coil is new, is it good?
Old 02-16-2013, 04:30 PM
Hmmm didnt know that could cause the problem...
Its got a brand ew CPS but i doubt the gap would be out of measurment, its been sitting for 5 or moe years
Old 02-16-2013, 06:57 PM
Okay so here's what I got today..
I turned the key but the engine isn't running obviously
And I put my 2 connection testers on the positive and negative of the coil
It lit up on the positive and negative but not on the inside of the coil, the park that connects it to the distributer...
What does this mean?!?
Old 02-16-2013, 07:44 PM
downhiller's Avatar
livin large
so you have power to the coil, just no spark to the dizzy cap?
either the ecu isnt getting the signal from the cps cause the cps is bad or has improper gap or the wiring is damaged from woodland critters, the ecu is bad, i know theres a couple more but the booze are effecting my train of thought
Old 02-16-2013, 08:28 PM
No well I've got something that tells me of power is coming from the coil that makes a spark. So what I've concluded is no power to the coil..
Brand new CPS as well, I might just take it to BMW and let them diagnose the problem and I fix it at home..
Old 02-17-2013, 12:28 PM
onager onager is offline
Mein Auto: 87 E30 325i
If I understand correctly you have 12 volts going to the coil. If so you won't see the high voltage until shorts out at the plug and causes the spark.
I have seen carbon build up so bad in the dizzy cap that the spark was shorting out. A worn rotor would also be a problem. Five years of corrosion might be your problem?
Old 02-17-2013, 04:24 PM
Not sure, it turns over fine, pumps fuel but no power is sent to the ignition coil. In guessing go down the chain.. If the dizzy was bad it would still be getting power to the coil correct??
This is a pain in the butt...
Old 02-17-2013, 05:33 PM
downhiller's Avatar
livin large
well you said you have power to the coil, using a test light i guess. an easy test is to get a spark plug and stick it the the wire from the coil and ground the spark plug out in the motor. then have someone crank the motor as your watching for a spark. if you have a spark, change the dizzy cap and rotor.
if you dont have spark, redo the test with 2 spark plug wires. if you get spark, change wires cap and rotor
if you dont have spark, grab another coil and try that. if problem persists, there is most likely a problem with the ecu or wiring
e30 325is no spark problem
