6 Series
Old 03-04-2013, 04:59 AM
Carter650i Carter650i is offline
Mein Auto: 650i
Navigation disc slot
This is crazy, I thought I did not have the dvd map for my 6r so my dealer went on and got me one, when I tried to put it in it wouldn't go in so since I'm not too familiar with the car I'm thinking that I need to push it a lil hard when I did that it still didn't wanna go in so my instinct kick in, I said to my self there's no way BMW will make this so damn hard to deal with so I pull the dvd back when I did that another navigation disc slightly comes out so I pulled it all the way out, and I tried to put the dvd back in after I took out the other one still no luck I tried the eject button nothing. So I'm thinking I probably have at least 2 more disc in there so my question is is there a way I can remove them without really do too much like take the dash down n stuff?
Old 03-04-2013, 10:38 AM
645/333's Avatar
645/333 645/333 is offline
Michael
Mein Auto: Black Sapphire BMW Z4 3L
I doubt that you have more than one disc in the slot!! You would really have to slam the disc in to do that !!!!! when you present the disc you only need to push in slightly and then the drive recognises the disc and it takes over running it into the slot! when the disc is removed it ejects to about 2/3rds of the disc.
If the last disc as you mentioned was ejected by the drive itself then I would say as above you only had one in!!!! You could also try an Idrive reset, there is a thread for this!!!!
Does my bum look good in this !
Old 03-04-2013, 11:22 AM
Mein Auto: 650i
I found that thread to no luck, the driver doesn't make any noises its almost like theres no power
Old 03-04-2013, 11:40 AM
645/333's Avatar
Michael
Does the CD drive release a disc????? (not the Nav DVD drive) the one below!!!! if yes it would suggest there is power to the unit
Old 03-04-2013, 11:42 AM
Mein Auto: 650i
Yes it does, well the nav slot is damage cause its still doesn't take the cd
Old 03-04-2013, 11:50 AM
645/333's Avatar
Michael
I think there is a thread about jammed discs, and how to release, sorry but I cannot remember the exact period, it may also have been on the E60 forum!!! I will attempt to find it if I can, you are definitely not the first to suffer this !!!!!
Old 03-04-2013, 11:51 AM
Mein Auto: 650i
I hope not. And i hope you find it.
Old 03-04-2013, 05:57 PM
HerbP HerbP is offline
When the IDrive boots up, are you getting a Nav disc not installed? Is the disc that you got removed, east coast or west coast?
Old 03-05-2013, 05:23 AM
Mein Auto: 650i
System says insert disc , east
Old 03-05-2013, 10:41 AM
reytran's Avatar
reytran reytran is offline
Nothing quite like a 6
Mein Auto: 09' 650i Cabrio
I got this before and luckily it was before my factory warranty is out. My problem was, I took out the disc, put in the 2012 disc. It couldn't read so I took it out again and never be able to put it in again.
I remember a guy at Al&Ed told me that he has to remove the trim then take the dvd drive out. Then it's pretty much similar way to the normal PC thin DVD drive.
2009 BMW 650i Cabrio (daily drive)
2011 Audi A4 (groceries, bully, road trip, winter beater, family car)
BMW CCA ID: 473647
Old 03-05-2013, 10:43 AM
Mein Auto: 650i
Wow ok!!
Old 03-05-2013, 01:09 PM
645/333's Avatar
Michael
This is good as the DVD recognises that the slot is empty (so no multiple discs jammed in) it also means there is power to the DVD. Just out of interest have you tried any other CD into the slot, not the NAV DVD!!! Present the disc gently as I found that if you push to hard you come across a stop, the drive itself does not make a lot of noise until it is hunting on a disc!!!
Old 03-05-2013, 01:14 PM
Mein Auto: 650i
The CD player above the DVD slot works as soon as I put a cd it takes it the DVD slot is not doing that. It doesn't "swallow" the cd or DVD like the cd slot on top of it...
Old 03-05-2013, 04:39 PM
I saw this message once when I put my west coast disc in by mistake. It just sat there & did nothing. This happened on my 7 series when updating my disc. At least it sounds like the DVD has power.
Good Luck
Old 03-06-2013, 05:45 PM
GetMeABeer GetMeABeer is offline
Mein Auto: 05 645Ci
Never shove a disc in, if it doesn't just slide in, auto take in actually, there's already a problem. If you didn't mess up the drive, try a reset, otherwise it's probably spent.
