E36 (1991 - 1999)
Old 02-16-2013, 11:12 AM
bimmer claus's Avatar
bimmer claus bimmer claus is offline
Santa
Mein Auto: 95 M3
323is Tranny.
Was under the car replaced the 02 sensors today saw the oil cooler rubber lines are leaking tranny fluid pretty bad . Tranny has 160k on it no knowledge as to when the last fluid change was done...Should I just re-pump some fresh fluid in through the side hole or.... go option b and go all out and replace the filter gaskets and fluid. Just nervous about changing fluid on a tranny that has atleast over 160k miles on it.
Opinions...Thoughts?
Lots of junk.
Old 02-16-2013, 11:15 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
It is never a bad idea to replace your tranny fluid.
It really should be done at least every other year or ~50k miles.
If any issues present themselves after the fluid change, they were about to happen anyway in my experience.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-16-2013, 11:17 AM
Santa
Mein Auto: 95 M3
You guys think I should go for it then i mean the current fluid probably has 160k on it....Any ideas on the cooler lines should i just try and clamp them down tighter a whole new set is 300ish...
Lots of junk.
Old 02-16-2013, 11:20 AM
jonesin's Avatar
The Canadian Prick.
For that price, you'd be better off with a manual swap
Chip still has one for sale... ... ...
Old 02-16-2013, 11:24 AM
Santa
Mein Auto: 95 M3
Price? I thought that there were tuning issues with the ECU's and what not if you swap
Lots of junk.
Old 02-16-2013, 11:26 AM
jonesin's Avatar
The Canadian Prick.
idk his price, just pm him? miles trail is his username. For those who've successfully done the swap ask CJ, Frank, Chip, Randy, Chad, Jared and Usama if memory serves.
Old 02-16-2013, 11:27 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
i believe that obd2 can be reflashed to manual trans status.
df
Old 02-16-2013, 11:30 AM
Santa
Mein Auto: 95 M3
df
Anyone wna chime in on this ive got an engine with 60k on it and a tranny with 160k if i could do the tranny swap and save my car id be more then happy to spend the extra...I thought you had to get a different ECU then get it mated to the car if memory serves me....
Lots of junk.
Old 02-16-2013, 11:34 AM
jonesin's Avatar
The Canadian Prick.
If you do a quick google for E36 swap thread BF.c has a very comprehensive one that should be useful to you.
Old 02-16-2013, 11:36 AM
afaik it's a simple process to either 'bypass' the wiring, but since obd2 is a flashable eprom (eeprom) it's as easy as reflashing the software.
it can be done on the e38 as i was looking to do a swap on a 740i, which was available in europe from the factory.
i don' see why the e36 would be any different.
df
Old 02-16-2013, 11:48 AM
dc_wright's Avatar
dc_wright dc_wright is offline
bimmerfest Supporting Member
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
It's a myth that changing the fluid and filter on an auto tranny causes failures. Most of the time what drives the fluid change is the transmission acting up, then the fluid gets changed, then the failure that was already in process happens and the fluid change gets blamed.
You can either swap in an OB2 manual tranny ECU or get yours reflashed. A check of the shops around your area to see who will do the reflash and how much they charge will help you decide on reflash or swap out.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 02-16-2013, 01:15 PM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
Honestly, I'd start simple and change your fluid and clamp down the leaking lines.
If its still acting up, them do a swap.
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 02-16-2013, 08:00 PM
Santa
Mein Auto: 95 M3
Just got home P1423 and P0420 codes are what i'm getting searched it seems to be secondary air pump? Anyone have experience sounds like more vacuum leaks
Lots of junk.
Old 02-19-2013, 01:12 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I haven't done a full swap yet, but it is on my list. The E36 can still be driven auto-manual swap without coding, but you'll have wonky things, like no reverse lights unless you wire in your own switch, etc. If you want it fully oem style, I think you just need a new DME and wiring harness. Not 100% sure, though.
I'd start with topping off/changing the fluid. The transmission works by pressurizing the fluid, and if there's not enough of it, bad things happen.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 02-19-2013, 01:15 PM
Santa
Mein Auto: 95 M3
On that note added ATF fluid today she took almost a quart and a half
It feels better but the engine is giving me odd hesitation still. At a constant RPM the MPG needle will skip back and forth without me moving the accelerator....anyone ever had an issue like this? I checked Vacuum hoses quick didn't see anything too noticeable...
Lots of junk.
Old 02-21-2013, 08:46 AM
Santa
Mein Auto: 95 M3
Update just got back from Advanced Auto code p0133-Oxygen Sensor Circuit Slow Response (Bank1, Sensor1). In short my primary 02's probably shot YAY. Also recently switched from 93 octane to 89 because my Dad insisted i'm wasting my money. I'll need a replacement 02 anyone know off hand the best to buy from. Plus should i go back to 93? It ran like a top on that gas. Thanks guys.
Lots of junk.
Old 02-21-2013, 08:52 AM
B1MM3R's Avatar
B1MM3R B1MM3R is offline
Jesse Moon Bayne
Mein Auto: e36, e46 & e70
I would never run anything other than 93. I can't b/c of my tune, but before the swap with my m42 I always ran 93.
Jesse
"Cassie"///Mpowered 93 318is 5speed (S/C'd 95 m3 swap)
2007 X5 3.0si (Wifes)
2001 330i DD
Old 02-21-2013, 08:53 AM
Santa
Mein Auto: 95 M3
I'm no tune and I think its worth it $4 extra a fill up to know its getting some better fuel not a waste IMO.
Lots of junk.
Old 02-21-2013, 08:56 AM
jonesin's Avatar
The Canadian Prick.
In laymans terms, the higher octane gas will burn slower, and achieve more complete combustion. It costs more, but will give you better MPG to offset it. Try it for yourself, run a full tank of 89 octane then one of 93 and see which yields better results. Then the math is easy as to which is more cost effective for you.
Old 02-21-2013, 08:58 AM
B1MM3R's Avatar
Jesse Moon Bayne
Yea Ed is right, but I have always felt my car(s) have ran much better on 93....just a cleaner/smoother running car IMO.
Jesse
2001 330i DD
Old 02-21-2013, 09:01 AM
Santa
Mein Auto: 95 M3
Mine always ran better on 93 too. Atleast I think.... it's one of those weird things you can feel I guess Idk maybe I'm just weird . ...Is there a way to test 02 sensors without throwing them in the car? It's kinda cold and theres a foot of snow so I'd rather only change it once
Lots of junk.
Old 02-21-2013, 09:03 AM
B1MM3R's Avatar
Jesse Moon Bayne
To be honest these cars throw o2 sensor codes all the time. My car got a new one 2 years ago and when its really cold outside my CEL still comes on as o2 sensor bad.
Jesse
2001 330i DD
Old 02-21-2013, 11:37 AM
Santa
Mein Auto: 95 M3
Update number two just swapped out two sets of 02 sensors - froze my arse off- no luck same symptoms no change at all. My question is can this somehow be related to the secondary air pump? I had the code a few days ago for it pop up and then disappear I just read that there was a service bulletin issued for it so ima go search and see what I can find.
Lots of junk.
Old 02-22-2013, 08:10 AM
Santa
Mein Auto: 95 M3
Filled up with 93 octane this morning no change. Things I've done so far..... swapped 02's twice with extras I had no difference either time ( I can't confirm whether they were good or not) I did notice that the 02 i had cleaned up only a couple days before already had a lot of soot on it and what not.Could this just be from the horrible running and it dumping fuel? Also Looked over vac lines to find any leaks, nothing obvious at this point. Pulled the MAF cleaned it up a bit and did the MAF unplug test it is indeed working. Pulled the SAP got it cleaned up a little bit re grounded it ...works fine now. Checked the ground wire that hooks up next to the SAP from what I understand it is one of the main engine grounds cleaned that up...no change. Running out of ideas guys. Thinking of taking the throttle bodies off the intake manifold and cleaning up all the gaskets and trying to check for any potential vac leaks from the lines to the icv etc.....Might have to really jack it up and get underneath to check the precat 02 wiring for any potential damage...
Lots of junk.
Old 02-22-2013, 12:38 PM
yeswecan yeswecan is offline
Mein Auto: Washington, dc
Well, my 323is is leaking the tran fluid from the tran radiator returning hose....it looks pretty bad....
I'm about to change, because keep adding new oil is not the solution
