E39 530i Service Engine Soon light - Bimmerfest - BMW Forums
Old 02-16-2013, 11:23 AM
brent1946 brent1946 is offline
Mein Auto: 2003 530i
The "Service Engine Soon" light came on a few days ago in our 2003 530i. The car runs great, has 90,000 miles and no apparent problems. Using the BavAuto code reader that I've had for awhile, I had some strange results:
- Read 'E10' then '--' first time which seems to mean no fault codes.
- Repeating the same check, it reads '--' which I take to still mean no fault codes
- Followed the reset SES sequence and it appeared to work.
The 'SES' light comes back on each time. The code reader appears to work correctly and I've gone through the sequence several times, still no fault codes and still get the SES light.
I read somewhere where a small battery on the service indicator card can fail and cause problems. Has anyone seen this before?
Thanks for any suggestions.
Brent Smith
Atlanta, GA
Old 02-16-2013, 12:23 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
SI is a different system than the SES light.
You're not the first to have a problem with E10 and the E39:
http://www.bimmerfest.com/forums/sho...d.php?t=373281
http://forum.e46fanatics.com/showthread.php?t=564360
Try the procedure in the second post.
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 02-17-2013, 08:32 AM
Thanks for the input. The E10 code apparently was bad communications. This was removed when I reversed the "power on" sequence. However, like the original note in the second post, I still get "--" or no fault codes, reset the SES light and then the SES light still comes back on. This was addressed partially in the newer on-line instructions for this BavAuto code reader. The only remaining answer I see from the instructions is a comment about a possible auto transmission fault triggering the SES light but not having an engine fault code that I can see.
Old 02-17-2013, 11:26 AM
Fudman's Avatar
Fudman Fudman is offline
That's pretty weird that you don't get a code with the SES and it keeps coming beck after being cleared. If you have an auto tranny fault, you would get a different fault message (TRANS PROG FAILSAFE) on the dash display. When you reset the SES with the car off, does it come back immediately after you restart the car? Have you tried to reset the SES with the car running? Other than that, disconnect the battery for 10 minutes and then reconnect to see if that clears it up.
Old 02-18-2013, 10:30 AM
No transmission fault on the display. Still no fault codes listed. Tried to reset the SES light while car was running. SES light immediately comes back on and stays on each time the car is started. I have not tried to disconnect the battery yet, but I will this weekend.
Old 02-24-2013, 02:41 PM
I disconnected the battery for about 15 minutes. Reconnected, started the car. The SES light is still on. Still no fault codes. Still can't reset the SES light. The car runs great. Surely I am not the first person on this board to have this problem. Any ideas?
Thanks.
Brent Smith
Atlanta, GA
Old 02-24-2013, 02:53 PM
HTK12 HTK12 is offline
Mein Auto: E39 540i
Get the codes pulled at BMW indy or test a different code reader. When SES is on there is a code. Can that code reader pull codes from all modules on the car? SES will be triggered for any fault that effects emissions. So it can be something else than just an engine fault code.
Old 02-24-2013, 03:51 PM
The code reader/reset tool is Bavarian Auto's SR300. It is supposed to read all of the BMW codes as well as the standard OBDII codes. I think that something else is going on here. Possibly a malfunction in the DME to instrument panel connection or a software hangup. Has anyone followed the instrument panel software reset steps in the Bentley manual?
Old 02-24-2013, 11:08 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I'm confused.
I can understand reading the internal BMW codes for things that are not OBD related, such as the transmission or the airbag ... but why NOT use a standard OBDII reader for the SES light?
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
What more is an internal BMW code going to tell you when it comes to codes that trigger an SES?
Old 02-25-2013, 12:06 AM
Mein Auto: E39 540i
I still would get the codes pulled with another code reader. That is by far the easiest way to start diagnosing. The manual on that reader talks about th battery in the cluster, but no E39 has a battery in the cluster only some older BMW's have it.
Originally Posted by bluebee View Post
I'm confused.
Well a good code reader gives you freeze frame data, that can include revs, battery voltage, how many times it has happened etc.
Old 02-25-2013, 07:11 AM
AnotherGeezer's Avatar
AnotherGeezer AnotherGeezer is offline
Entwicklung 39
Mein Auto: 2003 530i/5
That SR300 looks similar to my Peake.
The Peake has never failed me yet.
OP, have you checked to see if your gas cap is sealing properly? One of the common SES triggers and probably the easiest to fix.
Old 02-25-2013, 07:50 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
I believe Georgia is a state that allows any ol' regular auto parts store (like Autozone/PepBoys/O''Reillys/Advanced Auto/etc) to read OBD II codes...and they usually do it for free. I would drive to the nearest one and have them read your codes (possibly reset them) so that you can see what OBD diagnostic trouble code (DTC) is being registered. The DTC codes ("P" codes) are easier for the "masses" to diagnose since they are universal & based on the federal mandate that's been in place since 1996 (in the USA). The "P" codes can also be found doing just a simple google search.
It may also reveal if there's something wrong with your code reader, too. If another reader can't pull up any codes...then you know that you have a deeper problem, but if another reader can, then the problem is with your code reader.
Again, the DTC "P" codes can easily be found doing a google search...for example if you were getting a P0128 code...you could type "BMW P0128 OBD II" into a google search box and get lots of info.
Q {BMW CCA Member #191509}
(SOLD)
Old 02-25-2013, 11:23 AM
bluebee's Avatar
Does the code reader the OP is using give him that data?
(It would be nice to see freeze frame data, for once, just to see what it looks like.)
Old 02-25-2013, 11:43 AM
Mein Auto: E39 540i
I doubt it. Scanners like INPA, DIS (aka GT1), Autologic etc. will give you freeze frame data, live data.. I do find those quite useful when diagnosing issues. Especially when I'm diagnosing someone else's car (I help out local bimmer enthusiast with error codes, coding modules etc.).
Old 02-25-2013, 11:50 AM
bluebee's Avatar
It would be useful to see a picture of live data giving useful information for diagnosing an E39 problem so, to see if we can find some of that, I opened a separate thread just now:
> E39 (1997 - 2003) > How useful is "freeze frame data" for an E39 diagnostic over a typical OBDII scanner?
I use the $25 el cheapo scanner depicted in this thread when I have an SES light:
But, I often see mention of 'Freeze Frame Data' being useful, as in this thread today:
I'm sure more data is good data (trust me on that!) ... but ... from a practical standpoint, from people who have used freeze frame data, how USEFUL is it?
The reason I ask is that I myself can always use a better tool; but even more importantly, I often recommend the el cheapo scanner - but I really don't know what I'm missing in the next-level up.
Plus, there are the BMW diagnostic tools to consider when moving up from el cheapo:
- INPA, EDIABAS, NCS Expert, DIS, EasyDIS, Progman, & other BMW factory & dealer programming, coding, and diagnostic software & cable interfaces (1)
So, I guess my question is threefold:
Q: How useful is "freeze frame data" for an E39 diagnostic over a typical OBDII scanner and over the classic BMW dealer diagnostic PC tools?
Note: Example screenshots on your E39 would be nice.
Old 03-03-2013, 08:25 AM
I finally had my local BMW independent look at the situation. The transmission torque converter is slipping and needs to be replaced. Apparently the BavAuto (Peake) can't read transmission-related codes--and, in fact, the manual says that the SES light may be on and no codes found due to some "transmission-related problems." I'm a little disappointed in the 530i transmission for failing at 90,000 miles. The car has been well-taken care of (transmission fluid changed at 60k) and not driven hard. In comparison, I have a 1986 300E Benz that has 283k on the clock with no transmission problems at all (other than the front seal seeping). My independent wants $3,500 to rebuild the transmission--he won't just replace the torque converter--and will guarantee it for three years. I am pondering next steps.
Brent Smith
Atlanta, GA
Old 03-03-2013, 09:06 AM
Entwicklung 39
I'd be disappointed too. One of the reasons I stay away from automatics is that they can fail at any time for no apparent reason.
Heat is usually the biggest contributor to the premature demise of an automatic and as everyone knows, these cars make a lot of heat.
Old 03-03-2013, 10:49 AM
Mein Auto: E39 540i
Brent Smith
Atlanta, GA
That is why I don't understand why people pay big bucks for readers like BavAuto/Peake when there are better option out there for fraction of their price. How did the indie diagnose the issue? I would take it to shop that specializes in transmission to make sure. If the torque converter is indeed faulty just get it replaced.. It costs $400 + labor to replace it. Here's a link to shop that sells it for $400
Old 03-03-2013, 12:34 PM
Severe550i's Avatar
Severe550i Severe550i is offline
Registered Loser
Mein Auto: 2011 F10 550iX M-Sport
Torque converter failure is common, just search this forum.
I had the same issue and had a transmission shop install the TC for me. They were happy to just charge labor on a part I provided. Of course, there was no guarantee on the part, but you can find a reputable supplier if you use the above advice or search elsewhere.
FWIW, I would gamble $1,000 bucks on a new TC rather than rebuild the whole transmission.
Old 03-03-2013, 12:59 PM
Thanks for the advice. However, it's my wife's car and I don't want to take any chances. As a musician, she takes long trips and can be out late at night. If it were mine, there's no question that I would just replace the torque converter.
Old 03-03-2013, 01:03 PM
Mein Auto: E39 540i
I'm not saying it isin't, but many times shops don't know how to diagnose transmission issues, hence I recommended to take it to a transmission shop to be sure.
Old 03-03-2013, 01:59 PM
Severe550i's Avatar
Registered Loser
I looked back to see what exactly I did when my torque converter went bad. I went to the local BMW dealer and paid for a diagnostic test to read my fault code (P0741) and it indicated a torn seal in the torque converter. I then searched this forum and performed a highway RPM test to confirm this as well. I researched my options and found a solution that worked for me (and still works 3 years/+40,000 miles later) for ~$900.
I suggest finding out 100% what the problem is first. It's odd that the code reader doesn't provide a fault code, so that needs to be clarified before the OP should put in a transmission if it doesn't need one...unless he wants to.
Old 03-03-2013, 03:31 PM
Mein Auto: E39 540i
Double
Mein Auto: E39 540i
I looked back to see what exactly I did when my torque converter went bad. I went to the local BMW dealer and paid for a diagnostic test to read my fault code (P0741) and it indicated a torn seal in the torque converter. I then searched this forum and performed a highway RPM test to confirm this as well. I researched my options and found a solution that worked for me (and still works 3 years/+40,000 miles later) for ~$900. I suggest finding out 100% what the problem is first.
OP could do as you did or just take it to a tranmission shop that would do the required tests to be sure what is the issue. Someone who repairs these daily can diagnose these issues fast and accurately. Some indies diagnose things right and some don't. I know too many cases when indies have said that you need to replace X without properly diagnosing the issue first. When the TC fails soon after it starts to disintegrate and small pieces start to travel inside the transmission. These can destroy the transmission. So just replacing the TC is a bit of gamble.
OP gave a perfectly good explanation why he couldn't get fault codes from transmission:
Old 12-15-2013, 08:48 PM
patrick94115 patrick94115 is offline
Mein Auto: BMW 2003 530i E39
How can I turnoff check engine light? Code P0741 has been diagnosed on my 2003 BMW 530i e39. I would really appreciate any information, I'm over due for smog........
THANK YOU,
Patrick Mozingo
