E36 (1991 - 1999)
Old 02-17-2013, 07:33 AM
my99bimmer my99bimmer is offline
Mein Auto: 328i 325xi X3 M3
Front end rebuild
I recently replaced the front control arms, control arm bushings, sway links, sway link bushings, and tie rods. Now the steering wheel is rotated a bit to the left. The top is at approximately at 10 o'clock instead of 12. It drives fine but is annoying. I still have to replace the steering swivel joint. It looks like I can rotate the steering wheel where I want it after I remove the joint. Does this sound right? Also, is it best to do it before I get the alignment done or do it after?
Old 02-17-2013, 09:18 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Best to do it after alignment.
Sent from my U8651T using Bimmer App
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-17-2013, 10:00 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Absolutely do not re-center the steering wheel by removing it and then putting it back on. Doing so will cause you to have more available steering angle in one direction than the other (bad). The reason your steering is off is because the new tie rods you installed were not adjusted to the same length as the old ones you took off. You MUST get an alignment after doing this work. Get all of your parts replaced, then get an alignment.
1998 BMW 328is
1966 Pontiac GTO
Old 02-17-2013, 10:04 AM
hornhospital's Avatar
D'oh, You Kids!
The steering swivel joint is only supposed to go on one way. There are alignment marks on the shaft and the steering box shaft that align with the slots in the joint's clamps. That's so (theoretically) the steering column shaft and stub shaft on the steering box remain in the same relationship.
The alignment shop is supposed to align the wheel setting to match the steering wheel while centered. You are never supposed to have to move the steering wheel to match the alignment.
Quotes to live by:
Old 02-17-2013, 11:02 AM
Glad I asked!!!! The right tie rod had a little bend in it. I got the new one as close as I could. Thanks for the responses!
Old 02-17-2013, 11:10 AM
ZeGerman's Avatar
Warm Leatherette
Also, make sure you get that alignment ASAP, and don't drive the car in the meantime. If you do, you will undoubtedly scrub the tread off of your front tires very, very quickly. If the toe angle is wrong (as is the case in your car), you can kill a brand new tire in under 100 miles, easily.
1998 BMW 328is
1966 Pontiac GTO
Old 02-17-2013, 11:15 AM
The alignment is set up for Tuesday.
Old 02-19-2013, 03:05 PM
Alignment done. Thanks again for preventing a big mistake!
