Old 02-17-2013, 01:22 PM
bzcat bzcat is offline
Mein Auto: 2013 Q5 3.0T / 2012 335i
Top off engine oil with Mobil 1 5w-30?
My E93 is low on oil (iDrive says add 1 qt) so I call the dealer and they said I have to make an appointment to get an oil top off
So I'm just going to do it myself... I have a case of Mobile 1 5w-30 which I use for my other cars. I read that the factory oil fill on my BMW (car has 9,000 miles so still has the original oil from the factory) is Castrol. I assume Mobile 1 and Castrol blend is ok? I don't think it is an issue but I don't know if the BMW oil has any special chemical that may cause problem if blended with another synthetic.
Old 02-17-2013, 01:30 PM
d geek d geek is offline
diesel evangelist
Mein Auto: Volvo V60+ Volvo S80
Your car requires BMW LL01. Only use oil meeting that spec (especially important if in warranty)
Old 02-17-2013, 02:17 PM
David Williamso David Williamso is offline
David W
Mein Auto: 2007 335I E93 & E92
you are probably not far from an oil change, adding one quart of normal synthetic will be fine.
David
Old 02-17-2013, 02:30 PM
jburke4689 jburke4689 is offline
Mein Auto: 2007 335i
Mobil on 0W-40 meets the LL-01 spec and anyone who sells the 5W-30 will have it too. Just use that.
Old 02-17-2013, 03:11 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
Mobil 1 is fine.... alternatively get 1 litre pack of LL01 from local dealer
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 02-17-2013, 05:18 PM
pointandgo's Avatar
Mein Auto: '13 F10 535i (loaner)
My owner's manual clearly states that it is OK to top off with a non-BMW brand oil...and further states that "BMW recommends Castrol." I've also used Mobil 1 5W-30 to top off in the past.
F30 320i
F30 328i
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
Member: BMW CCA
Old 02-17-2013, 05:27 PM
diesel evangelist
On-line owners manual states that up to 1 qt of non-BMW spec oil can be used if it meets the API SM spec.
Old 02-17-2013, 07:27 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
for mobil 1, it should be 0W40 not 5W30. although for a top off, it should be ok, just be aware that M1 0W40 meets bmw specs while the M1 5W30 does not, so for a full change, M1 0W40
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 02-17-2013, 07:38 PM
mryakanisachoad's Avatar
mryakanisachoad mryakanisachoad is offline
Mein Auto: 550xi / 135i / M5
I don't think that's true at all.
Your oil cap says to use Castrol.
BMW doesn't refine their own oils, they buy it from oil companies like Castrol.
Old 02-17-2013, 07:51 PM
diesel evangelist
Maybe its time for you to read your manual and figure out what the BMW LL01 is for.
They don't refine their own oil, but like any top end auto manufacturer they make oil standards for their vehicles.
Old 02-17-2013, 07:52 PM
bear-avhistory's Avatar
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
But I believe it uses Germen Castrol as the BMW oil not the US version. Auto Zone carries it in some stores & its labeled Made in Germany on the bottle. That being said if you can't get Castrol get Mobil 1.
Kevin
CURRENT:
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2014 BMW 435M-Sport MPPK/MPE 8ZF
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 02-17-2013, 08:33 PM
xxE92's Avatar
xxE92 xxE92 is offline
Mein Auto: 335i E92
An interesting thing happened at my last service, I noticed on the invoice that the engine oil used was Liquid-Moly that happened to be BMW LL- 4. Of course my Indie thought he was using the correct grade but I had misgivings about this and contacted the account manager for Liquid-Moly and he confirmed to me that BMW LL- 4 is designed for diesel engines. He advised me to take it back to the shop and have it changed with BMW LL-1 as soon as possible. After much communication my oil was changed for free and they are now using LL-1 on all petrol BMWs.
Old 02-17-2013, 09:04 PM
Maybe its time for you to lose that horrible attitude lol. Seriously - you ok?
Old 02-17-2013, 09:11 PM
marine24 marine24 is offline
Mein Auto: 2007 BMW 335i
The better question is why you haven't changed your oil for over 9k miles? Just change your oil and call it good. Just because BMW says to change it every 15k doesn't mean it's a good idea (it's actually insanity if you ask me).
Old 02-19-2013, 04:25 PM
It's a lease... Not my problem after 30,000 miles.
I change my own oil on the cars I own, Mobile 1 every 5,000 miles... that's why I have cases of that stuff. I stock up at Costco when they have the $10 off coupon (like this month!)
So anyway... for the benefit of someone searching for the topic later, I was suspicious that the car really needed 1 qt so I topped off the car with 0.5 qt Mobile 1 5w-30 and remeasured and it was near to the max (was at min before the top off). So basically, if I had added 1 qt as the car had instructed, it probably would have over filled.
The car says oil change is due in 1,200 miles and I know the dealer will do the change once it is below 1,000 miles. So we won't be driving around with the mixed oil for long.
Old 02-19-2013, 06:24 PM
Last Sight's Avatar
Last Sight Last Sight is offline
Mein Auto: BLT335xi, e92 6MT
That's what I understand it to be, too.
BMWCCA #489063
The BLT335xi - '11 BMW 335xi, M-Sport, Convenience, Premium, H/K sound, iDrive
1974 Corvette - blue, 4spd, fully loaded
Previous Rides:
'13 Cadillac ATS - Fired
'09 BMW 328xi - KIA by Bambi, reincarnated in Michigan
'01 Saab 9-3 2.0T
