Old 02-18-2013, 09:07 AM
ryushe ryushe is offline
Driving with a permagrin
Mein Auto: '04 E46 M3 6MT
Question '03 Z4 3.0i engine whine (with audio)
Hi guys,
Hope someone here might be able to tell me what the hell the noise I started hearing 3 days ago is. I haven't been able to get a 'good' audio recording of it before, but finally managed something last night and this morning.
As mentioned, the whine/noise started about 3 days ago, and seems to go up in pitch when RPM increases. It's mostly at 1000 rpm and above when I hear it, although I heard the noise this morning too while idling. As far as I can tell, it's a constant noise, besides disappearing below 1000 rpm. Engine performance has not decreased at all far as I can tell.
Here's a link to the audio.
First piece of the audio is the whine only being present when at higher (1000>) RPMs, the other is the whining noise when idling (rare). It's coming from the front of the engine bay, close to the belts, and increases in pitch with increasing RPM. Any ideas on what it might be?
Some extra info that might be interesting: I replaced the belts around +/- 4 months ago, along with a new mechanical belt pulley. Engine has run around 78000 miles. Temperature around here has been anywhere from low 40s (5/6 C) to high 80s (28/30 C)
Old 02-18-2013, 09:56 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
I would start with the belt tentioner for sure.
Old 02-18-2013, 10:15 AM
I forgot to mention that your serpentine belt could also be bad.
Old 12-30-2015, 11:46 AM
GioZ4 GioZ4 is offline
Mein Auto: Z4
found the cause?
Originally Posted by ryushe View Post
Hi guys,
Hi ryushe, even found the cause and cure? I may be having a similar issue, at least my engine sounds the same..
Cheers, Gio
Old 12-30-2015, 12:09 PM
Cheers, Gio
Yeah, if I remember correctly it was the engine mounts that were shot. Replaced both of those and it all sounded perfectly normal again.
Old 12-30-2015, 02:21 PM
Mein Auto: Z4
Okay, thanks. Out of curiosity: what did make that sound you think? In my car, it sounds asif the noise comes from the oil filter (house)
Old 12-31-2015, 07:46 AM
hyojyang88 hyojyang88 is offline
Mein Auto: 03 Z4 3.0i
engine, noise, whine, whining
