Old 02-18-2013, 09:02 AM
cynsatim cynsatim is offline
Mein Auto: 2001 M5, 1983 Euro 635CSI
2001 M5 Airbag troubles- Can't reset light
Hello all. I'm about to sell the beast, and I have an airbag light on that I'd like to take care of before I send her off. Here's a little background on the issues I've had: Airbag light has been on for some time. There was no communication from the module to the OBD2 connector. After much troubleshooting and wire hunting, I found there was a broken connection between the instrument cluster and the OBD2 connector. I repaired that and now have communication with the module via INPA. I consistently get 6 errors. I reset them using INPA, but they immediately return. Here they are:
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 02/18/13 09:05:49 ECU: MRS3 JobStatus: OKAY Variant: MRS3-------------------------------------------------------------
RESULT: 6 errors in error memory !-------------------------------------------------------------
13 ignition circuit ZK12 -> airbag driver stage 2
Error frequency : 1
error active at the moment resistor too small error is not sporadic-------------------------------------------------------------
12 ignition circuit ZK11 -> airbag passenger stage 2
Error frequency : 1
error active at the moment resistor too large error is not sporadic-------------------------------------------------------------
11 ignition circuit ZK10 -> battery unplug 1
Error frequency : 1
4 ignition circuit ZK3 -> airbag passenger
Error frequency : 1
2 ignition circuit ZK1 -> belt tensioner driver
Error frequency : 1
1 ignition circuit ZK0 -> airbag driver
Error frequency : 1
I've searched and searched and searched and can't find much info on these specific error codes. Before I start tearing the car apart to start trying to figure out what's wrong, or give up and go straight to the stealer to figure it out, I figured I'd ask you all and see if you had any ideas. The car is a 2001 M5, stock. I have a spare airbag module that I coded to the car using NCS expert and it gives the same codes, so it seems to be something with the car and not the module. Any help is much appreciated!
In an effort to provide as much info as possible, I've attached three screenshots of what I see in INPA for the module.
ID:	362802   Click image for larger version
ID:	362803   Click image for larger version
Name:	Read Status.jpg
Last edited by cynsatim; 02-18-2013 at 09:29 AM. Reason: Added screenshots (xps) for added info
Old 02-19-2013, 06:05 PM
To help anybody out that may have these problems in the future:
Passenger airbag showed resistor too large. I had no idea how easy it was to pop the passenger airbag cover off. Found that the connector had been disconnected. Turns out the previous owner was a bag of crap and had disconnected it. Great guy apparently. Reconnected the connector, reset the light, and I'm now down to four codes!
Pulled out the driver's airbag and found that the connectors that plug in to the airbag were damaged. I fenagled one to work as a test and reset the light. Now only three errors! I will order the new harness and expect this one to be resolved.
So in my case, resistor too large indicated an airbag not plugged in. Resistor too small indicated a damaged connector at the steering wheel. The airbag itself has a spring in the connector that shorts to the pin, and I think when the cable is damaged in allows the spring to contact the pin, creating a very low resistance circuit.
Next step is to look at the seat belt tensioner. Resistor too large = it's disconnected? We shall see.
I'm still at a loss for the battery unplug fault. I'll look more in to this one in the next few days and post my findings.
Old 02-19-2013, 06:12 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
?has your car ever been crashed?
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
