Old 02-18-2013, 07:22 PM
fortunateson fortunateson is offline
Mein Auto: 525i
Exclamation Engine UNDER heating?
For the last couple of weeks I've noticed that my temp guage stays below the mid-point which it always reached before. I did have to top off the coolant by about a pint. SO... low coolant level preventing it from reaching operating temp? I would think it would overheat if this was the case. Any ideas? Don't seem to see any white exhaust so I don't think I'm burning coolant. Outside temps have been from upper 30's to mid 40's.
Old 02-18-2013, 07:26 PM
cn90 cn90 is offline
Replace tstat (Wahler or BMW only).
Then review your cooling system service records.
Old 02-18-2013, 07:34 PM
Mein Auto: 525i
Replaced the the t-stat about 3 years ago with brand recommended on this forum. Any other ideas?
Old 02-18-2013, 08:26 PM
StLMO StLMO is offline
Mein Auto: 535i
I recently purchased a car with the same exact issue. I'm not 100% on the other 5 series thermostats, but when the thermostat on an M5 fails, it stays open causing the car to run cool. My indy shop told me that it's not good for the car since the car stays in an open loop and will run rich. Any shop will be able to diagnose for you when the car warms up to know if it's definitely it. Good luck.
Old 02-18-2013, 08:58 PM
Mein Auto: 525i
I just can't believe that a t-stat wouldn't last 4 years! I'll check it out.
Old 02-19-2013, 12:27 AM
I'd start with how the thermostat works under normal conditions:
- What is the temperature of the coolant & when the thermostat opens under normal conditions (1)
