Old 08-11-2013, 09:15 PM
Red13_Scion Red13_Scion is offline
Mein Auto: 1997 BMW 528i
Oil all over bottom of Engine and Transmission
Could this be because of a leak on the top or front of the engine? Has anyone else had this issue? Any common causes?
ID:	391103   Click image for larger version
ID:	391104   Click image for larger version
ID:	391105   Click image for larger version
ID:	391106   Click image for larger version
Old 08-11-2013, 09:42 PM
riro424 riro424 is offline
Mein Auto: 2003 525i
Likely culprit is the oil filter housing (OFH) gasket. $6 part but 4 hours of wrench time.
Start here (CN90's DIYs are very helpful):
http://www.bimmerfest.com/forums/sho...d.php?t=414315
Might look into other parts that might need replacing while replacing the OFH gasket.
http://www.bimmerfest.com/forums/sho...d.php?t=530342
Old 08-12-2013, 06:42 AM
eparayno's Avatar
eparayno eparayno is online now
Mein Auto: 2001 530i
Power steering hoses and oil filter housing gasket are the culprits when you have an oil leak on the drivers side. Passenger side oil leaks are almost always valve cover related(gaskets) Also check your oil pan bolts and see also see if your oil pressure sending unit has oil around it. Mine has a leak. It's on the bottom of your oil pan with a wire loom attached to it.
Old 08-12-2013, 03:24 PM
shaftdrive's Avatar
shaftdrive shaftdrive is offline
Matching beemer & bimmer
Mein Auto: 1999 K1200 & 2001 525
OFH is number 1.
VCG is number 2.
CCV is number 3.
Old 08-12-2013, 05:11 PM
csw8331 csw8331 is offline
Mein Auto: 2001 530i, 2011 4Runner
also check vanos oil line and dipstick tube o-ring
Old 08-12-2013, 05:16 PM
Burning2nd's Avatar
Burning2nd Burning2nd is offline
Under the lift arms
Mein Auto: E39 540, E36 328is, E83x3
its self lubricating
true story..
some of the best old bimmers that ive seen where ones that leaked for ever... oiling the chasis, stopping rust from starting..
someone like me or some of you comes along 20 years later... snag's it for nothing.. replaces every seal and gasket it has... and has a fresh clean non rusted classic car for another 200k
Specializing In BMW, Audi, Mercedes Benz ,Volkswagen, Volvo
15486372<-----
