E36 (1991 - 1999)
Old 02-18-2013, 05:49 PM
HakenTT's Avatar
HakenTT HakenTT is offline
Mein Auto: '91 E30
328i/M3 stock dual exhaust is horrible for performance
here is the picture from one of the catalytic converters from 96-99 328i/M3 mid section, element is only 2.5 inch wide, exhaust from the 3 cylinders is hitting this element at an sharp angle. Flow of this will equal straight 1.5 inch pipe. This is horrible.
Old 02-18-2013, 05:54 PM
BMRfanatic's Avatar
BMRfanatic BMRfanatic is offline
Mein Auto: Bad Luck 46
What would you recommend as an exhaust? There is an approvement compared to the 325/obd1 M3 right?
Sent from my SPH-D710 using Bimmer App
-Dino
Old 02-18-2013, 06:10 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
compared to other factory exhausts, the //M3 is heavy, but flows well. aftermarket units are nice because they do tend to have less sharp angles, a factor when considering mass produced vehicles, and are lighter. however, from what i have seen, these can be just as pricey, if not more, than oe components.
that being said, the obd2 pipes are more free flowing than the obd1 counterparts since there is no pinch @ the cat.
also the dual pipe design all the way back is another factor to consider. when converting to a signle pipe design, one needs to consider this, as well as the wall thickness (bmw oe pipe is rather thick) and how it affects the scavenging affect closer to the exhaust manifolds.
i have a modified obd1 pipe with a high flow cat, to a single outlet. my butt dyno has not recorded any loss of power, but since i didn't make a before video i cannot claim for certain exactly how much hp and tq i have gained.
but it feel like a lot....
df
Old 02-18-2013, 06:42 PM
southpark11235's Avatar
southpark11235 southpark11235 is online now
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
I have both a 328 and 323 exhaust in my basement right now. Does anyone know a way that I can test the flow of both exhausts and end this debate?
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
//1992 Mazda Miata - cat delete, power windows, oil filter relocation
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 02-18-2013, 07:02 PM
dc_wright's Avatar
dc_wright dc_wright is offline
Send a message via ICQ to dc_wright
Mein Auto: '06 Z4 3.0si, '11 128CiC
Duct tape a leaf blower on the front end and the biggest trash bag you can find on the other. Measure the time it takes for each to fill the trash bag. It's crude but it's quick to rig......
If you want something more objective use the same leaf blower but you'll need to rig a T fitting of some type off the front end to connect a pressure gauge that can measure low pressures. This is a direct measure of back pressure and whichever exhaust measures the lowest reading flows the best.
2006 Z4 3.0si Sport Package (But I'll still hang with my "homies" in the E36 forum)
Old 02-18-2013, 07:23 PM
If I measured the back pressure on both 328 pipes, then add the two numbers together and dived by 4. Would that give an accurate reading?
Old 02-18-2013, 07:52 PM
dc_wright's Avatar
That should do it!
Old 02-18-2013, 08:05 PM
cj.surr's Avatar
cj.surr cj.surr is offline
some kid
Mein Auto: whiny 318
There's no debate of 323 exhaust vs 328 exhaust. 328 is obviously better, and nobody that knows what they're talking about will disagree. You don't have to waste your time testing it.
-CJ
Old 02-18-2013, 08:29 PM
Originally Posted by dc_wright View Post
That should do it!
Great, I order a cheap little air pressure gauge off eBay. It should be here next week. As soon as it comes I will do the test and post the results.
Old 02-19-2013, 05:54 AM
RawrRawr RawrRawr is offline
Hello!
Mein Auto: A bike; 1996 328i Sedan
It should be here next weak.
Please fix this, kind sir..... It bothers me, oh so much. It's like how people spell brakes as breaks.
'96 328i BMW, Auto
Old 02-19-2013, 09:48 PM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
Replace your suspension, cooling system and do a manual swap!
It bothers me, oh so much!
