Old 02-18-2013, 10:41 PM
galahad05's Avatar
galahad05 galahad05 is offline
Better with Butter
Mein Auto: 335i sedan 6MT
Your Opinions? Hit a chunk of ice at speed--$8.6k damage...
Took out my driver's front wheel/tire, and lots of left-side suspension pieces.
I'd like your opinions:
What do you think, will she ever drive the same? Should I get rid of her?
Here's the claims adjuster's estimate of things that have to get fixed.
1 FRONT LAMPS
2 REPL LT HEADLAMP ASSY W/ADAPTIVE 1
H'LMP
3 ADD FOR ADAPTIVE HLMP 0.2
4 REPL LT FOG LAMP ASSY 1
NO. OP. DESCRIPTION QTY EXT. PRICE LABOR PAINT
5 AIM FOG LAMPS
6 STEERING GEAR & LINKAGE
N 7 REPL LT TIE ROD ASSY RWD B14% 1
8 REPL LT BOOT 1
9 REPL GEAR ASSY RWD 1
10 FRONT SUSPENSION
11 O/H FRT SUSP LT M 3.5
12 REPL LT STRUT W/SPORT PACKAGE SEDAN 1
13 ALIGN FOUR WHEELS M 2.0
14 REPL LT STRUT SUPPORT 1
15 REPL LT STRUT SUPPORT GASKET 1
16 REPL LT REAR CNTL ARM NUT 1
17 REPL LT REAR CNTL ARM 1
18 REPL SUSP CROSSMEMBER 1
19 DEDUCT FOR OVERLAP -0.4
20 DEDUCT FOR OVERLAP -1.0
21 REPL LT FRONT CNTL ARM BOLT 4
22 REPL LT FRONT CNTL ARM NUT 2
23 REPL LT FRONT CNTL ARM 1
24 DEDUCT FOR OVERLAP -0.4
25 RADIATOR SUPPORT
26 REPL FRONT SHIELD RWD 1
27 REPL UNDER COVER W/O AWD 1
28 REPL FRONT SHIELD SCREW 10
29 REPL UNDER COVER WASHER 3
30 REPL FRONT SHIELD NUT 14
31 FENDER
32 REPL LT FENDER LINER REAR 1
33 REPL LT FENDER LINER FRONT 1
34 REPL LT REAR EXTN NUT #1 6
35 WHEELS
N 36* REPL LT/FRONT WHEEL, ALLOY STYLE 1
162 8X18
37 TIRES
N 38* REPL PIR P225/40ZR18 PZERO NERO 1
M+S BW 88W
39 ELECTRICAL
40 REPL TRANSMITTER 1
41# REPL SOCKET HOUSING BLACK - 1
61136907388
42# REPL BLADE TERMINAL CONT - 2
61130007272
43# REPL UNIVERSAL SOCKET HO - 1
61138365356
44# REPL BUSHING CONTACT - 61130005199 2
45# REPL UNIVERSAL SOCKET HO - 1
61138365340
46# REPL SOCKET TERMINAL SLK - 1
12521427608
47# REPL AIR DUCT FRONT LEFT - 1
51747160609
48# REPL HEX HEAD SCREW WITH - 2
07119905241
49# REPL SCREW WITH WASHER - 2
31106769907
50# REPL HEXAGON SCREW WITH - 2
31106769908
51# REPL HEXAGON SCREW WITH - 2
31106767497
52# REPL HEX SCREW WITH COLL - 6
33326768354
53# REPL PLUG IN NUT - 31106779393 2
54# REPL CAGE NUT - 31116768715 2
55# REPL HEX BOLT WITH WASHER - 4
31106763928
56# REPL LOCKING NUT - 31106767496 2
57# REPL COMBINATION NUT - 33306787062 4
58# REPL SELF LOCKING COLLAR - 2
33326760668
59# REPL SCREW SELF TAPPING - 3
07146967731
60# SUBL NYS TIRE DISPOSAL FEE 1
Don't resent growing old. Many are denied the privilege.
-- Irish Proverb
Old 02-18-2013, 11:05 PM
CALWATERBOY's Avatar
Mein Auto: 2009 E93 N54
My opiinion: Winter driving's best done in a pickup or large SUV.
There's not much a 7,000 lb diesel can't goosh through, rain, sleet, or snow. Make it a 4x4 w/LSD and you got a go anywhere, mondo ground clearance, don' care if I bump anything, total comfort machine.
Yours is a case in point - sporty cars drive well on dry pavement at pleasant to warm temperatures.
Old 02-18-2013, 11:10 PM
galahad05's Avatar
Better with Butter
I hit a chunk of ice that had fallen off of an overpass so hard it bounced the front end of the car clean off the ground, then slammed it back down--HARD. I expect anything short of a Baja 1000-ready off-roader would have some trouble with that.
-- Irish Proverb
Old 02-19-2013, 02:44 AM
lqaddict's Avatar
lqaddict lqaddict is offline
Salz und Pfeffer
Mein Auto: 2014 F22 M235i
1 FRONT LAMPS
H'LMP
5 AIM FOG LAMPS
8 REPL LT BOOT 1
10 FRONT SUSPENSION
25 RADIATOR SUPPORT
31 FENDER
35 WHEELS
162 8X18
37 TIRES
M+S BW 88W
39 ELECTRICAL
61136907388
61130007272
61138365356
61138365340
12521427608
51747160609
07119905241
31106769907
31106769908
31106767497
33326768354
31106763928
33326760668
07146967731
I am finally getting my car tomorrow after a misfortune earlier last month, the car had the lower subframe and rails replaced. I will let you know if it drives the same.
BMW CCA Member 454031
Save the manuals
Old 02-19-2013, 04:25 AM
Banned
Mein Auto: 2007-335 HTC
it might drive the same, but I bet you think it doesnt drive the same, the new driver wont know the difference
Hondo
Old 02-19-2013, 04:49 AM
Aha! That's bad luck, and outside BMW's brief. Guessing it was lying there....maybe fused to the road....vectored you & your ride t'6"+ altitude?
Name:	Hair on fire.gif
Old 02-19-2013, 07:10 AM
galahad05's Avatar
Better with Butter
Thank you gentlemen, for your opinions.
I'm hoping it drives just like before when I get it back....otherwise I don't know what to replace it with.
My dilemma: I don't know if I like anything out right now that comes close the my current car's level of fit/finish/performance for anywhere near the price. Including the new F30.
-- Irish Proverb
Old 02-19-2013, 08:01 AM
chris328's Avatar
chris328 chris328 is offline
unbekannt
Mein Auto: 750Li Hi-Sec, '13 Actros
8.6k? wow
Old 02-19-2013, 08:08 AM
Pilgrim's Avatar
Pilgrim Pilgrim is offline
Car guy since 1968
Mein Auto: 2008 E91 328xi Sportwagon
If it's done well, it should be OK. Make sure you're happy with the result before signing off on the work.
1983 Datsun 280ZX Turbo
2000 Jeep Grand Cherokee
2008 BMW E91 328xi Sportswagon
2009 BMW E92 328ix Coupe
Old 02-19-2013, 08:22 AM
MP3_E46's Avatar
MP3_E46 MP3_E46 is offline
Code/wrench Monkey
Mein Auto: Carefully
A clean non accident 2007 E90 335i is worth ~$15K ($12->13K at current auction prices ). After that damage.. who knows?
$15K - $8.6K = $6.4K
If you can get a check for $8.6K I'd do that, sell the car for parts and get a new(er) car. Or keep the old one and DIY fix for a track car - I'll take it off your hands for $6.4K and even let you have a lap or two at the next track day
Six Euro Deliveries since December 1998 (Owned E46, E90, E91, E92 and E93)
28 vehicles in 26 years of driving so far. Guess I like cars
Old 02-19-2013, 11:02 AM
BBMW528i BBMW528i is offline
Nice Guy
Mein Auto: 09' BMW 328i; 04' BMW X5
07 335i is worth WAY more than 15k. I still see them easily in the 20's
Old 02-19-2013, 11:17 AM
MP3_E46's Avatar
Code/wrench Monkey
Try trading one in without buying another. Dealers typically ask for ~$5->6K more than they paid and settle for $3->4K more. Few will pay $20K for a six+ year old three series.
http://www.kbb.com/
Old 02-19-2013, 11:29 AM
chris328's Avatar
unbekannt
A 2007 is a 6-7 year old car. After 4 years it is worth 15-20k. After 7 probably 10-12.
Old 02-19-2013, 12:24 PM
galahad05's Avatar
Better with Butter
Eh, insurance has already cut me a check for ~$8100.
I'm going to have them begin repairing it. If it turns out not to drive so well, I'll trade it in and get something else. Maybe a Jag XFR?
-- Irish Proverb
Old 02-19-2013, 12:57 PM
LarkHouston's Avatar
LarkHouston LarkHouston is offline
Doing the best I can
Mein Auto: 2013 Porsche Boxster S
That sounds like you were lucky it was just the car and you weren't injured. This is just another reason I live in the south. Sorry but it is 68 and sunny today. Perfect top down weather for the Z.
2015 Audi SQ5
Recent Past:
2009 335i Coupe Dinan S3
2006 BMW Z4
