Old 02-19-2013, 05:33 AM
Giz11 Giz11 is offline
Mein Auto: 2002 745i 1992 850i
DSC, Dynamic Drive, Speedo, ABS, Servtronic TV Faults
There seems to be quite a few posts on similar problems but no clear resolution
My faults started with a parking brake error which went on for about 2 months. I check the cables and drive cogs but all was fine. Then I had a DSC failure which added to the fault, the steering felt very light with this error. Then at random I had a Dynamic Drive Fault, usually present when the engine was warm. With this fault the speedo died and when I looked at the secret menu on the instrument clusted the momentary speed read 409.7 kmhr even when stationary. The TV also assumed that the car was mobile when actually stationarry and did not turn on. With the Dynamic Drive error the ABS fault indicator comes on and the reversing sensors stay on.
Is there a logical trouble shooting process, I feel it may be a sensor and not a series of faulty modules. All help greatly appreciated.
Car drive fine though.
Regards
Giz
2002 745i
Old 02-19-2013, 05:36 AM
Piers1989 Piers1989 is offline
Mein Auto: E65 745i
I would guess something to do with your wheel speed sensors / the DSC control module.
Everything that is not working is linked to the speed of the car, so I would check there first.
Old 02-19-2013, 07:41 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
Sounds like your ABS modules is going bad.
Old 04-19-2013, 06:02 AM
los2much's Avatar
los2much los2much is offline
Mein Auto: 745li
Sounds like abs module or a bad alternator. By the way how is the supercharger mod going. You left everyone hanging on the final results and sound clip.
Old 04-21-2013, 06:08 AM
Sorry for the lack of posts, just been consumed by work.
I have not fixed the faults yet but soon.
The car has great power, still fumbles when cold but when it goes, it goes well.
I will change out the plugs soon and see if we can tweek a few things.
I do find that there is a long lag in changing gears when under power.
Will do a sound recording soon as well
Regards
Giz
Old 04-21-2013, 09:25 PM
Gene1986 Gene1986 is offline
Mein Auto: 750i
Integrated power supply module
Old 04-23-2013, 10:28 PM
los2much's Avatar
Mein Auto: 745li
Video clip please. I'm getting the supercharger soon and have yet to hear the sound and power it will make.
