E34 (1989 - 1995)
Old 02-19-2013, 01:18 PM
E34ZombieHunter's Avatar
E34ZombieHunter E34ZombieHunter is online now
Nothin like an E34
Mein Auto: 95 540i B/B
Dash issue
This is what my dash does when it is below 50 degrees F, is it normal? It takes 30 min to one hour to show all the way up.
Old 02-19-2013, 01:22 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
that is definitely not supposed to be like that.
Normal wear though...
PIXEL FIX!
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 02-19-2013, 01:30 PM
Nothin like an E34
What one is for mine, my dash looks like none of those. This is after 30min idle with heat on full.
Old 02-19-2013, 01:44 PM
Monsignor's Avatar
Mein Auto: Sig
google search E34 dash pixels. E39 and E38 guys CONSTANTLY have this problem. Being as i'm not an either of those, and my pixels are fine, I dont have much to contribute off the cuff...
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 01-30-2014, 06:14 PM
Nothin like an E34
So time to resurrect this old beast. I still have the issue after replacing the ribbon cable. Last time i removed the cluster when doing the faces i checked the connections and they were fine, and clean. If i press down on the dash above the cluster they all light up fine. Also light up fine once the car is warm. But still nags me because if the OBC wants to tell me something before i leave it cannot.
Gotta love an E34!!
If you want to get junkyard parts remember one thing, if it was wrecked you know it was running/driving. You may not know how well, but it was.
READ THE STICKIES AT THE TOP OF THE PAGE!!
STOMP TEST
READ ME IM THE BIBLE
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 01-30-2014, 06:18 PM
Nothin like an E34
Here is recent pic with me pressing the check control button so it lights up too.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 01-30-2014, 07:08 PM
Doktor Bert's Avatar
Doktor Bert Doktor Bert is offline
Der Sturm Uberdoktor
Mein Auto: BMW 525i
I see that here in Cali in both extreme cold and heat. Extreme cold makes 'bars' show up and extreme heat (120+F in-car temps) make the display go solid orange...
"Herr Doktor will see you now..."
Old 01-30-2014, 07:15 PM
Nothin like an E34
Its below 50 and it happens, never fails. Ever since i got the car, even after the pixel fix.
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 01-30-2014, 08:33 PM
Mein Auto: BMW 525i
Same here. I've had mine since 2012 and it's always reacted like this to cold and heat...
Old 01-31-2014, 11:11 AM
mtlay mtlay is offline
Mein Auto: 1992 BMW 525i
Do a search on this board for the "cold weather fix". It involves removing and opening the cluster, and then replacing the electrolytic capacitors soldered into the circuit board. I have the same problem with my E34, but I haven't been able to do the repair yet. The hardest part may be finding the proper value capacitors (capacitance in microfarads AND voltage). Let me know how it goes, since you'll probably get to it before I do.
Sent from my SPH-L720 using BimmerApp mobile app
Old 02-10-2014, 03:38 PM
Try this link, it may answer some questions.
http://www.bmwe34.net/E34main/Mainte...Capacitors.htm
Old 02-10-2014, 06:16 PM
Nothin like an E34
Gotta love an E34!!
STOMP TEST
FAN CLUTCH
LOCKS
ANGEL EYES
Audio
E28 v. E30 v. E34
Old 02-14-2014, 10:04 AM
rainman0833 rainman0833 is offline
rainman0833
Mein Auto: 1993 525I
I'm having an issue with my cluster after changing the bulbs. Only my tachometer works now. The gas gauge and temp gauge work, but wrong readings. They're about a quarter off. My speedo doesnt work at all even with doing the cluster test. Would it be easier to buy a new cluster?? Don't want to mess with soldering any capacitors. Anyone in the Chicago area on this forum??
