Old 10-10-2013, 12:36 PM
Banned
Mein Auto: 2007-335 HTC
Bavarian Technic scanner arrived
Purchased the Bavarian Tech san tool. hooked it up to my 2007 335i convertible, it works! cleared a bunch of codes that were related to the ABS and brake light that is intermittent, so if it happens again, hopefully it will direct me to the issue
question is there is a lot of things that can be done with this tool anyone have suggestons of what I can do and what I should not do
also when I start the unit up it for traction control I have a choise
DSC and DXT, not sure which on I have the button on the Dash to turn it off is DTC
Old 10-10-2013, 12:49 PM
Zooks527's Avatar
Zooks527 Zooks527 is online now
Winding up the M235xi
Mein Auto: 2015 M235xi / 2005 Tacoma
DSC for a RWD car, DXT for an xDrive.
2015 M235xi coupe, Black Sapphire Metallic, Black Leather, Fineline Stream trim, Steptronic, xDrive, ZPP, ZTP, ZCW, ZDA, ZDB, 5DP, hk w/ BimmerTech amp, Enh. BT
Ordered 3/12/15, Off the line 4/7/15, Delivered 5/14/15
Prior 40 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette / 1981 Subaru GL wagon 4WD / 1983 s10 Blazer 4x4 / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion / 2009 BMW 335i xDrive E92
Old 10-10-2013, 01:19 PM
Banned
thats what I thought
thanks
Old 10-10-2013, 01:26 PM
roadkillrob roadkillrob is offline
Mein Auto: 325CIC, 335CIC
ABS and Brake light can be a few things - wheel sensor failing or loose connection can be one, that bad one is ABS pump going bad which is also a bit common unfortunately. Hopefully they don't come back, can occur from a low battery condition also.
2008 335i Vert Montego/Saddle/Grey Poplar
2013 Mercedes C63 AMG Obsidian Black/Black
2016 X5 M-Sport Mineral White/Mocha Design Package/Fineline Oak
Old 10-10-2013, 01:52 PM
Banned
well if its the ABS pump hopefully my extended warranty would cover it
Old 10-10-2013, 02:13 PM
surfcity335i surfcity335i is offline
Mein Auto: 2012 335i M-Sport
You'd better hope. In a domestic that pump is over $500. That's $2700 at the BMW exchange rate.
Old 10-10-2013, 02:55 PM
Banned
so if I slam on the brakes and the ABS pump, starts pumping the brakes, wouldnt that mean its not the ABS pump?
Old 10-10-2013, 02:57 PM
No. You could have an electrical anomaly in the pump that causes a code but doesn't prevent the pump from doing its job.
Banned
OK this thread has been side tracked, I am more interested in the Scan tool and what are its best uses???? when to us, what functions do I need to use and not use
