E36 (1991 - 1999)
Old 02-19-2013, 07:37 PM
Scott8199 Scott8199 is offline
Send a message via ICQ to Scott8199
Mein Auto: 1994 BMW 325i
My 94 325i is bouncy what should I do?
I have a 94 325i and its bouncy as all hell what is the best course of action?
Old 02-19-2013, 07:40 PM
SCJon SCJon is offline
Poet of Signature Quotes
Mein Auto: 1997 BMW 328is
Details please. Can you describe the bounce? Or when it does it? And I assume that you're not speaking about the engine RPMs.
"It doesn't do any good for me to know more than you if you aren't going to listen to me"
Originally Posted by petriej View Post
So let it be written, so let it be done.
Old 02-19-2013, 07:55 PM
It's bounces all over the road at virtually any speed just rocking back and fourth. It sometime bounces very high and slams to the ground pretty violently
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Ohhhh yeah!
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
drivinfaster's Avatar
Mein Auto: rescued bmw's
if you are talking about the idle, then try cleaning the icv.
if the car itself, as in when going over bumps, then check the struts and shocks. if there is any sort of banging or hard clunking, then you may have additional parts damaged that may not be related to the shocks or stuts.
it is just difficult to say based upon your description.
df
Old 02-19-2013, 08:04 PM
I'm sorry, it's just while driving that it bounces its hard to control at high speed 55+
Old 02-19-2013, 08:12 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
Replace your struts & shocks. You probably need all new bushings, control arms, tie rods, and everything else, too. If your car is so bouncy at 55mph that you can barely control it, it sounds like it's barely safe to be on public roads.
1998 BMW 328is
1966 Pontiac GTO
Old 02-20-2013, 08:52 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Check the shock towers too while you're replacing the shocks and struts and bushings. If you see any cracks or separation, find yourself an alignment rack and a very good welder. Then a wallet to pay for the repairs.
Old 02-20-2013, 10:27 AM
jitsjaf2009 jitsjaf2009 is offline
Mein Auto: 1995 325i Convertible
Struts and shocks....could be just struts. Push down quick and hard on front corner and see if it does up and return to level...same on each side (and rear if doubt the shocks). Old rule is should be "no more than 1-1/2 movements. If more stuts or shocks are bad and you are depending on springs to absorb road bumps....and they will bounce if no good shocks and/or struts. e-bay actually has some reasonably good deals...autohausaz.com.
Local Parts Stores are usually a bit pricey...you drive a BMW!!!!
Last edited by jitsjaf2009; 02-20-2013 at 10:31 AM. Reason: forgot the az on the autohausaz.com
