Old 03-09-2013, 02:37 PM
crcuevas crcuevas is offline
Mein Auto: 2001 740il
Need to identify this part!
Can someone please tell me what is or where does this bracket go? I took it off when I was doing my timing and and found laying around but don't know were it goes.
ID:	365569   Click image for larger version
Old 03-10-2013, 02:22 PM
c'mom? anyone? please help!
Old 03-11-2013, 01:03 AM
ebida3's Avatar
ebida3 ebida3 is offline
Society of the 7's East
Mein Auto: 2001 740iL
Talking
Go to www.realOEM.com and look at the diagrams. You should be able to ID the part. Just remember where you took it off and look at that section.
Old 03-11-2013, 11:51 AM
I did that all weekend and could not find it anywhere!!! I had it with my distributors pile (box) that I put all of them in.
Old 03-11-2013, 07:26 PM
kimokk kimokk is offline
**Bimmer DIYer**
Mein Auto: 00 740iL, 97 M3, 06 X3
It looks like the secondary air valve mount bracket that attaches on too of intake manifold passenger side. There should be an electronic part with two vacuum hoses coming out of it that attaches to this bracket. It screws on to the front bolt near the fuel injector wiring harness.
BMW '00 740il w/230,xxx miles, DIY timing chain guides complete! M60 Manifold, BDC Throttle Body, Performance gearing 3.46 LSD, Magnaflow Mufflers
BMW '97 ///M3/2/5 w/105,xxx miles
BMW '06 X3 w/130,XXX
Old 03-12-2013, 07:16 AM
can you show me on REALOEM which part it is?
Old 03-12-2013, 08:02 AM
**Bimmer DIYer**
Here it is on the engine:
Old 03-12-2013, 08:12 AM
Thanks Well i thought the same thing but that part is already on my car. Any other ideas?
Old 03-12-2013, 08:44 AM
**Bimmer DIYer**
Did you check both sides? Otherwise it could be bracket for oil dipstick. Do you know anyone else in your area that has an e38 tha t you can look at to compare?
Old 03-12-2013, 08:55 AM
Thanks for the quick response!! I check the other side also. No luck. I may just have to do that.
Old 03-12-2013, 09:04 AM
**Bimmer DIYer**
Is it #2 or #5 in this link?Realoem
Old 03-12-2013, 09:05 AM
Both of those brackets are on my car already. I just don't know were this goes!!!!
Old 03-12-2013, 09:20 AM
**Bimmer DIYer**
How about driver's side upper timing case. It holds the alternator wire.
Old 03-12-2013, 10:34 AM
Can you send me a picture or REALOEM?
Old 03-12-2013, 10:49 AM
**Bimmer DIYer**
Maybe part #22 here. Your best bet is to look at someone else's car.
Old 03-12-2013, 11:01 AM
Your right. Just got to find in the south (Biloxi) gulf coast.
