Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 03-07-2013, 06:33 PM
Amirof Amirof is offline
Mein Auto: BMW 740IL
Need help
Does anyone know how to replace a coolant hose that goes from the top of heat exchanger to lower water pump tee connector on a 2000 bmw 740 il?
looks half metal tubing with other half of rubber hose.
my problem is to how disconnect from heat exchanger(no access).
Any help is appreciated.
Old 03-11-2013, 07:47 PM
kimokk kimokk is offline
**Bimmer DIYer**
Mein Auto: 00 740iL, 02 530iA (hers)
You have to remove bracket first that is attached to bottom of water pump then slowly wiggle hose forward and back as you pull the hose to the passenger side.
BMW '00 740il w/196,xxx miles (his), DIY timing guides complete! M60 Manifold, BDC Throttle Body, Muffler delete
BMW '02 530iA w/140,xxx miles (hers)
BMW '09 R1200GS Adventure w/13,6XX Smiles
Old 03-12-2013, 09:12 AM
Thanks Kimokk, when i did that i broke the plastic bracket , so i had to replace that one as well, and to get to it, had to remove the wheel and inner fender cover.
Lots of work, but it's done.
Old 03-12-2013, 09:23 AM
**Bimmer DIYer**
That sucks. That piece gets welded in there some times. Always pull that one out firmly but gently holding the heat exchanger while you pull it out.
I removed mine when everything in the front was off. Didn't have to go through wheel well.
HTML code is Off
