E30 (1982 - 1993)
Old 02-19-2013, 11:42 PM
steezysloth steezysloth is offline
Mein Auto: 2000 323ci
Exclamation E30 no spark & fuel *UPDATE*
Okay so i posted a few threads down about not getting spark but not much help
New thermostat and housing
All new hoses and gas lines
New main relay
New fuses
New coolant sensors/switches
New flame thrower ignition coil
New battery
So im not getting fuel or spark/power to the coil
Replaced main relay and still no spark
Found out my fuel pump and o2 heater relays are bad...
so im guessing replacing those 2 will fix my no fuel problem haha
But as far as no spark/power to the coil, the car turns over and everything.
Im thinking it is the immobiliser/anti theft system causing me to have no spark
But i have noooo idea where the immobiliser is located so if someone can help me point it out and tell me how to bypass it that would be great
and any ideas anyone else has to why it is not getting spark
1989 325is manual
Old 02-20-2013, 12:07 AM
AndrewZ's Avatar
AndrewZ AndrewZ is offline
Super Moderator
Mein Auto: 91 E30
Have you replaced your cap and rotor?
Old 02-20-2013, 12:18 AM
Well if idk if it is bad, im not at that point of the chain yet, im not getting power to the coil ):
Old 02-20-2013, 12:22 AM
e34crank e34crank is offline
Mein Auto: 90 535I,89 735il
Check your DME aka fuel pump relay maby even ecu fried. Idk had the same problem with my e34 there's a whole thread on no start situations on here some where
Sent from my DROID RAZR HD using Bimmer App
Old 02-20-2013, 01:10 AM
@e34crank Thanks! Im def gonna go pick up those 2 relays tomorrow and stop by the scrap yard and pick up an ECU lol
Ill post back and see what happens....
Old 02-20-2013, 01:53 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Do these ECU's have a habit of dying ?
What causes this ?
I have yet to see a Japanese car's ECU die from anything but outside attack !
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 02-20-2013, 08:49 AM
hornhospital's Avatar
D'oh, You Kids!
Yes, particularly in cold weather. The solder joints are old, get brittle, and when they get chilled they pull apart just enough to break the connection(s). Reflowing the solder traces with a low-wattage solder iron/gun has saved many a 'dead' ECU.
Quotes to live by:
Old 02-20-2013, 06:32 PM
Good luck. Let me know if that doesn't work could even be clogged injectors if you didn't have your fuel regulator on water could have got in your fuel rail and rusted causing some blockage. Happened on a motor I bought off cl
Old 02-20-2013, 08:48 PM
Okay so i did some more digging today, tried those 2 fuses in a different spot and turns out they are actually fine, so the problem is im not getting power to my fuel pump and o2 sensor heater relay slots. ):
Tomorrow i will pick up an ECU from the scrap yard and see what happens i guess
I removed the fuel lines and held them trying to crank it and no gas comes out im guessing because those relay slots arent getting power ):
bypass, coil, ignition, immobiliser, relay, spark
