E34 (1989 - 1995)
Old 02-20-2013, 01:40 PM
530ifreak 530ifreak is offline
Mein Auto: 1995 530i
Cool Starting problem and coolant leak e34
My 95 530i is leaking coolant from the backside of the engine and is also not starting at times even though I replaced the alternator and battery if anyone has any ideas please help I'd love to get my e34 back on the road
Old 02-20-2013, 01:43 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
welcome to the fest. Please see the thread linked below and let us know if this is similar to your cooling issue.
Thread
We're going to need more information about the car. Are you handy and technically savvy?
1. Items to cause a no start
- Fuel
  • Fuel Pump
  • Fuel Pump relay
  • Fuel Filter
- Air
  • Air Filter
  • MAF
  • ICV
  • Throttle Position sensor
- Spark
Does the car crank but not fire? or just nothing with the turn of the key? Is it intermittent? or has it just stopped all together?
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 02-20-2013, 01:47 PM
I don't think that is my issue I'm not having overheating issues it just leaks from the middle if the rear if the motor I'm wondering I it could be a rubber line back there maybe ? Also I'm trying to locate the starter relay circut to see if it is okay or if its the cause of my starting problem
Old 02-20-2013, 01:52 PM
Monsignor's Avatar
Mein Auto: Sig
updated previous post, read through it
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-20-2013, 01:56 PM
Yes I am savy to the normal causes of a no start my car does not even crank randomly it will just not start I will put the key in and I get dash lights but it will not crank
Old 02-20-2013, 01:58 PM
Monsignor's Avatar
Mein Auto: Sig
not even starter motor spinning?
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-20-2013, 02:35 PM
Nothing at all it's as if the battery is dead but you still have all dash lights
Old 02-20-2013, 02:40 PM
Monsignor's Avatar
Mein Auto: Sig
i know you said you replaced your battery but this has happened to be on a dead battery. Yes, i still got dash lights.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-20-2013, 03:25 PM
But the battery is charged and bran new I tested it at work and its all fine
Old 02-20-2013, 04:30 PM
Microtesties Microtesties is offline
Unregistered User
Mein Auto: 1990 BMW 525i
Check ground connections!
Year: 1990
Model: 525i
Transmission: 5 speed
Mileage: 250k
Old 02-20-2013, 04:34 PM
Monsignor's Avatar
Mein Auto: Sig
Starter relay?
Sent from Joe's Galaxy Tab 2 via BimmerApp
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
