E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
Bleeding the cooling system question
So I bought my 93' 325i sedan 3 days ago and saw that the temp gauge was always up and down and then realized that my car never blows truly hot air. So i decided to try and bleed the cooling system by watching a DIY on these forums.
It seemed easy enough after watching the video so I went out and gave it a try. It seems no matter what I do I can never get all of the air bubbles out. I tried for 35 minutes last night squeezing the hoses and just kept on getting air bubbles out of the bleeder. Thanks for the help in advanced, this is my first BMW I have ever owned in my 7 years of driving so I am new to these car, but love turning wrenches and working on cars. Any light on why this could be? Thermostat possibly? and is it safe to drive this way?
You have to build the pressure back up after releasing the bubbles.
How I do it is drive car for few minutes till at operating temperature and then bleed. Drive car more then bleed. Drive car more then bleed. So on and so forth untill all bubbles gone.
Part out. http://bimmerfest.com/forums/showthr...67#post7418867 "Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI Stock 2004 X5 3.0i (Wifes) E30 87 325e |
OK thank you for the input, very much appreciated.
Is it safe to drive this way? Because i got work in about an hour and don't want to risk overheating it.
Dont let it get past 12 oclock operating temp. Do you have enough coolant in car?
Is the needle going past 12 oclock?
Nope doesn't even get to 12 oclock, get to just a sliver under. i know the guy put a new radiator in it in December of 2012 still have the receipts int he glovebox
SOunds like you got a bad thermostat. Seems like its stuck open not allowing to get to operating temperature.
Ok, so should I not drive it to work until i put in a new thermostat?
I mean its kind of hard on the engine to not get to operating temperature b/c the moisture in the engine never gets burnt off. Id not drive it untill I put one in it if was my car. Also get the aluminum one, the plastic ones stink.
Agreed, it does sound like a stuck thermostat. Keep bleeding the system until no more air comes out. If you keep bleeding it for days and days, and air stills gets in/comes out, you won't want to hear what we have to say...
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
Follow this video if you haven't already.
1996 Z3 (M44) |
Uh Oh! well hopefully the thermostat will fix the problem haha. Luckily one of my buddies runs a Euro Specialization shop so if I run into any problems I should be alright in that sense as long as I got the money to afford parts and some beer haha.
and yes this is the exact video I went off of
Its ok to run with an open thermostat, better than a stuck closed thermostat. Engine won't run optimally, you may get O2 sensor CELs, but its not the end of the world.
I believe you mean for him to replace his thermostat housing (plastic) with an aluminum one when he changes the thermostat itself.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
