Old 02-20-2013, 05:58 PM
jgriffith007's Avatar
jgriffith007 jgriffith007 is offline
Mein Auto: 2009 750 Li
Angel eye install
I know you guys have had several topics buy I got some mtech angel eyes for $30 on ebay and couldn't believe how easy the install was. Easily under 10 mins total. Happy with the outcome and for $30 can't go wrong.
Sent from my SPH-L710 using Bimmer App
ID:	363161   Click image for larger version
ID:	363162   Click image for larger version
Old 02-20-2013, 07:05 PM
wjjklj's Avatar
wjjklj wjjklj is offline
Mein Auto: 2013 BMW 750Li X-Drive
Did you replace your fogs too? How is the color match to the factory xenons?
Old 02-20-2013, 07:16 PM
BPHBimmer BPHBimmer is offline
Mein Auto: 11 750i XDrive MSport
Saw them on eBay but they are all 230.00 not 30.00. That was a good deal if u paid that. I ordered mine from alpine mss but they have not come in yet...
Old 02-20-2013, 07:25 PM
Color match isn't too bad. Didn't change fogs yet as I was wanting to see how these looked. Here is an ad they sent with the lights
delete, duplicate
Old 02-20-2013, 08:03 PM
Also, I did a search for F01 angel eyes and searched cheapest first to see if there was any low priced ones and these came up. No errors, no resistors
Old 02-20-2013, 10:17 PM
FULL 6 FULL 6 is offline
Mein Auto: 2012 750i MSport
I just ordered a pair too. 30.00. They code or get to hot, they will hit the trash can.
Old 02-21-2013, 12:50 PM
The color is bright white but not the same color of headlights... They have on e that is blue and that would probably match better. These just aren't yellow like the stock.. On my white drywall they have a blue hue but very light..
Old 02-21-2013, 12:56 PM
Are they as bright as Alpine 's 6000K
Old 02-21-2013, 02:18 PM
wjjklj's Avatar
E-92 lighting lists these lights as a fog light bulb. You sure you have the right light installed? 55 watts might be too hot in the angel eye socket.
wjjklj's Avatar
They are $22 on E92 lightings site.
Old 02-21-2013, 03:25 PM
batmbl's Avatar
batmbl batmbl is offline
Mein Auto: 2009 535i
Just had angel eyes installed. Should the 2 middle lights on a 08 550 shine when u put the car in reverse?
Old 02-21-2013, 10:25 PM
Tuesday Tuesday is offline
Mein Auto: .
All newer BMW's with adaptive xenons/LED's do this. It's your cornering lights and actually makes turning in the dark easier if you notice the side path illumination they give. At low speeds the lights will illuminate to correspond with your turning or indicator direction. They fade on/off and can be hard to see if you aren't looking...
Old 02-21-2013, 10:41 PM
f01driver f01driver is offline
Mein Auto: 11' 750i, 14' Bentley GTC
The issues with these bulbs is that at night they look great but during the day they're not visible unless you install high watt bulbs but installing high watt bulbs can cause damage. I went with PIAA's, the light is white and gets rid of the yellow and they're visible during the day.
Reference, the best lumens (visable light output) you will get will be from 4300K bulbs.
2011 750i
Old 02-22-2013, 08:40 AM
They are 35 watt. Had zero issues whatsoever but should have got the blue ones
Old 02-22-2013, 08:44 AM
Just took this pic but it's not sunny outside
Old 02-22-2013, 04:14 PM
Emilner Emilner is offline
Mein Auto: 2013 SL63
Do you know off hand which bulbs from piaa work?
2015 S550 Anthracite blue, Silk, loaded and doin just fine...
2013 SL63 AMG black....
2014 GL350 The kids chariot.
2012 750IL x drive, imperial blue/oyster, a finely loaded beater car... (gone)
2012 650 Cabriolet M sport (gone)
Old 02-22-2013, 07:11 PM
Kar Don Kar Don is offline
Mein Auto: '14 & '15 i3, now '16 i3
I'm also curious. These are stock halogen and won't yellow my housings right?
2008 Mercedes-Benz CLS550 Iridium Silver/Black Leather -- P2/321/881 (leasetraded 1/10)
2002 BMW 325i --Topaz Blue/Natural Brown Leather --SP/PP/HK/CWP/Bi-xenon (Sold 9/06)
Old 02-23-2013, 08:34 AM
are those the mtech? They still look yellow
Old 02-23-2013, 01:39 PM
PIAA 18235 H8 Xtreme White Bulb
The bulbs are close to stock color but whiter if that makes sense.
2011 750i
Old 02-23-2013, 01:52 PM
They are more noticeable at night but I should have got the blue ones to better match... This isn't too much of a difference in the day light.
Old 02-25-2013, 06:38 PM
GOT THEM TODAY- THEY ARE WORSE THAN STOCK. THESE LIGHTS SUCK!!! SHAME ON ME! LOL. DO NOT BUY THEM. AS MANY HAVE PROVEN FOR ALL OF US, THERE IS NOT AN EXACT NON DAMAGING REPLACEMENT OR RETROFIT TO MAKE OUR 7's LOOK OR PRETEND TO HAVE LED's...DO NOT WASTE YOUR MONEY
Old 02-25-2013, 07:55 PM
Did you get the blue ones or the white ones? I was just about to buy another set and get the blue ones
Old 02-25-2013, 08:20 PM
Blue false advertisement
Old 02-26-2013, 01:22 AM
Yup, don't waste your money...there's nothing on the market that will match the LED halos. Only way to get LED's is to retrofit the LED's on the 2013+ F01 but you're talking about a few thousands dollars to do the retrofit.
2011 750i
