E36 (1991 - 1999)
Old 02-20-2013, 08:53 PM
Smooth-E Smooth-E is offline
Mein Auto: 95 325i
Temp guage not working e36 325i
I recently had an engine replaced in my 95 325i, and the temp gauge was working before the replacement. I have changed the thermostat, temp sensor located on the head, completed a cluster test and the gauge works during test. What could be preventing the gauge from working?
Old 02-20-2013, 08:57 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
How isn't it working?
Not moving at all?
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 02-20-2013, 09:00 PM
Mein Auto: 95 325i
The hand does not move at all
Old 02-20-2013, 09:02 PM
jonesin's Avatar
The Canadian Prick.
Does the heater blow hot air?
Old 02-20-2013, 09:09 PM
Mein Auto: 95 325i
The heater does not blow hot air. While bleeding the system, the top radiator hose gets hot, but the bottom hose is warm at best.
Old 02-20-2013, 09:10 PM
jonesin's Avatar
The Canadian Prick.
Then your gauge is likely fine as you still have air trapped in your system.
Old 02-20-2013, 09:19 PM
Mein Auto: 95 325i
Will air trapped in the system prevent the gauge from working?
Old 02-20-2013, 09:38 PM
jonesin's Avatar
The Canadian Prick.
If it isn't warming up, then definitely.
Old 02-21-2013, 08:23 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
try to elevate the front of the car on jack stands and remove the cap from the coolant tank and allow it to sit over night. gravity should be able to force the air back to the top. other than that, turn the heat all the way up, fans to high and let it run while keeping an eye on things. if the thermostat doesn't open it's in backwards, defective, or there's air stuck still. I used to do coolant flushes all the time at work and i invested in a coolant flush kit which consists of a big bowl with an adapter that screws onto various coolant jugs, so you can fill it up and then let the car run and allow the air to work itself out without having to constant add more coolant. a temp gun, or temp leads for a multimeter help too, you can check the water temp and compare it against what the gauge is telling you.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
