Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 02-22-2013, 02:31 PM
StormGuy StormGuy is offline
Mein Auto: 2011 BMW 128i
Automatic door locks setting not working
I recently purchased a 2011 128i coupe for my wife. The doors locks will not activate or lock after the engine starts nor after sitting idle. I programmed the BC as per owners manual and the display indicates these functions are on. But the door locks will not engage. Any suggestions before I take it to dealership. All other programmable functions are working, i.e. courtesy lights etc.
Old 02-22-2013, 04:22 PM
Tom K.'s Avatar
Tom K. Tom K. is offline
Mein Auto: '07 328iT.'13 Boxster
Not sure if it has been changed on later model years, but on my '08, checking the autolock setting engaged the locks only after driving off - generally around 5~8 mph. Same on my '07 328i.
Tom
Old 02-22-2013, 04:57 PM
Thanks for reply. Yeah, I tried driving it after I programmed it. My Honda locks automatically when I reach a certain speed. I think it was working right before I took it to the dealership to have them do the 15k routine service. Is there a way to reset all settings to factory default and start over?
Old 02-23-2013, 04:30 PM
I believe my problem is the key fob. I tried the second fob and the doors lock automatically as described in the manual. So I have to figure out what can be done with the other key fob.
Old 02-24-2013, 09:51 AM
Tom K.'s Avatar
Assuming you have re-programmed the locks with the offending fob and they still don't lock, if you have comfort access, you might try replacing the fob battery (CR32). It's an easy DIY, described in the manual.
Otherwise, a defective fob should be covered under warranty.
Tom
Old 02-25-2013, 03:42 AM
Yeah I have tried reprogramming several times. Everything else seems to work with that key, but I' ll take it to the dealership and let them check it out. Thanks for your replies.
