E36 (1991 - 1999)
Old 02-21-2013, 04:41 AM
Jakobie1086's Avatar
Jakobie1086 Jakobie1086 is offline
Just a kid with a toolbox
Mein Auto: 330ti
Dremel bit INSIDE manual trans.
Long painful story short I'm replacing the gate pins/bushings/springs for reverse and 5th on my ZF S5-31.
I managed to get the 5th gear bushing out with an hour of using a screw driver and trying to compact it into a smaller piece to get it to come thorugh the bushing wall hole.
Time to do reverse bushing... yeah no not doing it the same way. So I got my Dremel and starting cutting away. I started with the wrong bit (sanding bit) and it broke and flew inside the trans and disappeared. I bought the right bit and finished cutting the bushing out.
Problem is now I have a dremel bit inside my transmition. I tried everything, shaking it and turning it every which way but I didn't even hear anything move.
Currently I'm going to flush about 8quaters of ATF oil through the trans to clean any metal shaving out, and maybe this dremel bit also.
Any ideas?
Old 02-21-2013, 06:09 AM
drivinfaster's Avatar
Mein Auto: rescued bmw's
didja try a running start first??
when you say dremel bit, you mean the sanding disk, like a mini cut off wheel??
i'd think regardless of what is in there it will wind up causing issues later on.
df
Old 02-21-2013, 07:34 AM
hnaz's Avatar
hnaz hnaz is offline
BMW CCA Member
Mein Auto: 128i M, M3, 530i M
Just flush the tranny with some cheap tranny oil for a while and that should do it. I'm sure the bit that broke will wash away during the flush. If not, just say you did a speed upgrade.
Old 02-21-2013, 07:55 AM
ReillyM3's Avatar
ReillyM3 ReillyM3 is offline
Mein Auto: 1994 325i sedan
If its a cutting wheel Id think that it would be decimated to dust and a flush would do it. But was it a grinding barrel?
1994 325i (current)
2006 325i (current)
1995 525i
1990 325i
1988 Jetta 8v
1987 Gti 16v
1985 Jaguar Xj6
1984 Jaguar Xj6
1966 Mustang
1965 Falcon Wagon
1961 Buick Special
1962 Buick Special Wagon
1955 Pontiac Cheiftan
1961 Falcon Tudor
1962 Faclon Ranchero
Old 02-21-2013, 08:11 AM
maybe a sort of rasp??
df
Old 02-21-2013, 08:15 AM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
ooof. flushing runs the risk of pushing the bits and chunks into the valve bodies. you might have some luck crafting a hose onto a shop vac that will fit into the hole you lost it down. other than that if the Autos had a pan you could remove, that's what i'd be doing.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 02-21-2013, 11:30 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
If you have time and patience you could tear the whole thing down. Would be good to do anyway.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual FS
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 02-21-2013, 07:16 PM
Mein Auto: 330ti
Bit looked kinda like this
http://static.hardwarestore.com/medi...5_front200.jpg
No metal, just that end part. The trans still isn't installed, and it into the trans through the gate pin hole and disappeared. If I can't flush it out, I was just gonna drive like 5 miles with the trans in then drain and re-fill the fluid, hoping that it gets stuck in between a gear and turned into dust immediately.
Not happy about this, just my luck
EDIT: Also, I pulled all the bolts to split the cases but it was stuck together. Didn't feel comfortable trying to pry it apart and I have no idea how to... and I couldn't find a single guide or repair manual.
Old 02-21-2013, 08:25 PM
probably not ever going to, either....i have been looking forever and still haven't found anything.
that stone is abrasive and will be ground down to dust eventually. however, it will also wear out the brass synchros an blocking rings if it gets in there....even if you do flush is out.
df
