E30 (1982 - 1993)
Old 02-21-2013, 06:21 AM
dinahbmw325 dinahbmw325 is offline
Mein Auto: 1987 325
Heater only comes on when turned to 4
Hi All,
So this just started yesterday, with of course at least another month of cold winter weather left in Virginia. The heater dial will not work unless I crank it all the way to 4. This morning, as I had it on full blast (20F degrees) and made a slight sharp turn, it sounded like there was a motor cycle at full rev inside my car, i promptly turned off my heater, the sound stopped. After being home for approx. 20 minutes, i headed to work and turned the heat on (all the way to the 4th setting) and it wasn't making the sound any more, but it definitely is still not working on lower dial settings. Help!! not sure if its the blower motor, or what. - thanks, freezing to death in VA
Old 02-21-2013, 07:59 AM
markseven markseven is offline
an audience of One
Mein Auto: Go Kart with AC
It's the Final Stage Resistor that has gone bad.
Old 02-21-2013, 08:03 AM
an audience of One
http://www.gutenparts.com/search-res...esistor&type=1
Old 02-21-2013, 08:09 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
This
Probably the single most common E30 problem
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 02-22-2013, 02:28 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
check your heater fan/blower also
Because you said you had a crazy noise when you turned a corner ,you should have a look at your the fan for the heater as well as the resistor .I've found they like to go out together .You can look in most repair manuals for the removal / testing procedure or if you message me I'll give you my phone # so you can call me an I'll walk you though it.
