Old 02-21-2013, 03:42 PM
cbell13055 cbell13055 is offline
Mein Auto: 05 CTS-V
Audi 22's on a BMW 750i
Buddy said I could have his Forgiato Concavo's cheap if they would fit on my car. Looking advice.
His wheels 22x10.5, 22x9.5 with 25mm offset front and rear....wrapped in 295/265's
With Audi to BMWadaprers would these fit???? And not run or look retarded
2008 Jet Black 750i. Sport, Luxury Seating, and Logic 7. <3
Old 02-21-2013, 06:04 PM
jkidem's Avatar
jkidem jkidem is offline
Mein Auto: 745Li
they will look good if the offset is right etc
2013 328i M Sportline
2003 745li sold
2000 528i sold
Old 02-21-2013, 06:09 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
Dont do it. Your going to have a high chance of vibrations.
Old 02-21-2013, 06:41 PM
Mein Auto: 05 CTS-V
San...why do you think vibrations?
I mean if the adapter is installed correctly and flush against the hub then theoretically it should be a flush extensions of the hub....no?
Old 02-21-2013, 06:42 PM
Mein Auto: 05 CTS-V
And those wheels look good!!!!i think if it would work why not right....just want to know if it can be done and consequences
Old 02-22-2013, 04:31 AM
DriftGirl DriftGirl is offline
SideShow activist
Mein Auto: 745Li
those will look nice. Just make sure you get hub centric adaptors or rings
Current Lineup:
BMW E31: Air suspension,19x10 / 19x11 Trafficstar
BMWE38:Air suspension,20x10 / 20x12 Forgiato (SOLD)
BMWE65: 22x10 / 22x11 Asanti ELT (SOLD)
Lexus SC400: Single turbo, 19" SRR wheels
Lexus GS300: VIP , Air Suspension,19" WORK wheels
S13 Silvia: WideBody, JDM conversion,SR20det,15" WORK wheels
Lexus LS430 UL:Air Suspension, 20"MAYA DLS
Old 02-22-2013, 06:15 AM
los2much's Avatar
los2much los2much is offline
Mein Auto: 745li
you ok long as its hubcentric to the wheel i ran adapters before
Old 02-22-2013, 07:06 AM
Mein Auto: 05 CTS-V
Is there a set standard for the adapter on siZe????
A wheel guy I'm good friends with took a lot of calculations and said I would need a 28mm in the front and a 41mm in the rear....does this sound about right????
Old 02-22-2013, 12:43 PM
SideShow activist
Mein Auto: 745Li
Impossible to calculate without knowing the offset of the wheels you're trying to run...
just remember that 28mm spacer is an inch or so.
****most off the shelf pcd conversion adapters are an inch if you dont get them custom made.
Current Lineup:
Old 02-22-2013, 01:47 PM
Mein Auto: 05 CTS-V
Hey drift girl
The wheels are 25mm offset front and rear
Any ideas??
Old 02-22-2013, 03:19 PM
GPDenver GPDenver is offline
Mein Auto: 2003 745i
My guess is most of the people on this forum don't have much experience with wheel adapters.
I have been running them on multiple cars for years now, and have not had any issues. Everyone on the Audi forums told me I was ruining my brand new 60k car, but I had no issues and was able to run a much more interesting wheel.
Adaptec is my favorite company for adapters, custom built to your specs. I think they can go as small as 22-23mm for adapters. I think you may run into rubbing issues with the wheels above, but the only way to know is to measure. Google calculating offset and go from there, but at et+2 front and rear that is more agressive than most people here run.
I run a more aggressive offset, something like et 0 front et-4 rear, but my wheels are 20x10 rear 20x9 front. I have no rubbing issues and have factory camber, with my fenders rolled.
With camber you may be able to fit them, but if you are new to wheel fitment this may be a bit over your head.
Old 02-22-2013, 03:30 PM
Mein Auto: 05 CTS-V
Hey GPDenver
I posted the calculations my wheel guy sent me. He says they should work. Can you double check and let me know what you think????
ID:	363408   Click image for larger version
Old 02-23-2013, 09:44 AM
Mein Auto: 05 CTS-V
Anyone else want to double check the numbers and tell me their opinion on fitment????
Old 02-23-2013, 03:53 PM
mrbmwx5 mrbmwx5 is offline
Banned
Mein Auto: 06 750Li
Hey drift girl
Any ideas??
I'm running on Vossen with 20mm Front and 27mm rear.
you should be ok ( +5mm and - 2mm) not much different there.
Just make sure the hub centrict are correct. ( same side)
Old 02-23-2013, 04:45 PM
Mein Auto: 05 CTS-V
Sounds good man! Yeah the only thing I wasn't sure of was the space the adapter added l. My wheel guy said with the 28mm from and 41mm rear it'll be just about perfect.
Old 02-24-2013, 01:33 PM
Based on the picture you posted above it looks like your new specs will be 22x9.5 et +8.5 front and 22x10.5 et +8. I don't run 22", but sounds more aggressive than the typical 22" for our cars. Will look great if you don't end up rubbing.
Ask all the 22" guys on the forum to post op their specs, find a set you like and copy the offset.
