E34 (1989 - 1995)
Old 02-21-2013, 03:09 PM
Rubbed Radish Rubbed Radish is offline
Mein Auto: 1994 540i
1994 540i trans slamming in and out of overdrive
Hello,
I have 94 540I with 170k. When driving on the highway the vehicle bucks and slams in and out of overdrive when i step on the gas. This started about 5 months ago, it started with it doing it every once in a while and now its doing it all the time and some times it down shifts hard and will start of in 2nd and shift to 1st when i take off. My question i have is, is my trans toast or could it be the trans computer also there is no trans message in the check control. Also will a 5speed trans from a 530i fit and a trans from a 740i or 750i? Thanks for your time guys and gals
Old 02-21-2013, 07:56 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
if you are putting your foot to the floor it will be engauging the kickdown switch, dropping down gears as its supposed to do
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 02-22-2013, 07:44 AM
That's not the problem, the problem is it SLAMS in and out of overdrive
Old 02-22-2013, 09:03 AM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
4 posts in and you know exactly what it isnt? Can you help us out. caps-locked "slams" isnt terribly descriptive. Help us help you. Maybe have a passenger record a video of it?
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 02-22-2013, 12:44 PM
A vid isn't going to show much it more or less felt in the transmission. I'm not sure if there is a overdrive lock out solenoid that I can unplug to not let the car go into overdrive.
Old 02-22-2013, 01:15 PM
Monsignor's Avatar
Mein Auto: Sig
any transmission problem, i would usually suggest starting with fluid. Yours may be low and it could act that way. Maybe its as simple as topping off fluid, hopefully.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 02-22-2013, 02:10 PM
yep. id say 60-70% of transmission errors in the E34 E36 era are due to low transmission oil
E30 above Sold
