7 Series - E38 (1995 - 2001)
My previous problem was this: The engine was shaking terribly. So I connedted the obdII reader and found code P1351 - Misfire Cylinder 5 With Fuel Cut-off. I read some time ago here int the forum that in order to diagnose this problem correctly was to move the ignition coil from cyl# 5 to the next cyl, cyl# 6 and drive the car for a couple of miles.
After driving it for a day, I had a cel. Connected the obdII reader again and found to have; code P1353 - Misfire Cylinder 6 With Fuel Cut-off! Which concludes that the ignition coil was causing the error msg or cel. Replaced the ignition coil, erased the code and hope the cel would not come up again. Wrong! It did showed up again after driving the vehicle for a day. And this time the error code was P0174 - System Too Lean (Bank 2)! Now the gas consumption is terrible! Read and went thru the service manual by Bently, I could not find a solution to cure this problem. Can someone help me solve this problem please!! Appreciate it! |
similar thing on my 2001 il and it was cam sensors, also make sure you do your pcv asap no matter who said its been done do it now so you know
new coil SET along with new spark plugs. The coils along with the plugs will run you about $450. If one is in crap shape the rest are soon to follow. dry rot, cracked leaking, etc
keep the coil you just bought for a spare.
-Tom |
It'll run lean if you have a vacuum leak or even an O2 sensor misreading. Make sure the coils are OEM not URO ones cause URO is absolute garbage. Nothing of theirs lasts longer than 1 month. Also replacing all 8 is recommended vs replacing one. Replace with used if replacing less than 8.. replace all 8 if replacing more than 2.
** Removed ** |
pcv
Where can I locate the pcv?
Rear of the engine. Keep in mind, I'm showing you the diagram for my car.
http://realoem.com/bmw/showparts.do?...81&hg=11&fg=40 Should be part # 11617501563 Photo... http://realoem.com/bmw/showphoto.do?id=11617501563 On a similar note, if I reassembled my engine and I didn't necessarily put the coils on the same cylinders, will this cause issues?
No issues , done it many times
misfires? check plugs and see if oil on them. if oil gets down in plugs that can make it misfire also.Check all plugs if u see even some oil on them. then check ur valve cover gaskets. then change ur o2 sensors. the front two not the back two. if it still is running ruff then check coil packs. from what my bmw tech said they dont go bad that often quick. and if you want to change them after doing all that yes change all eight not just one. check ebay they sale used ones for cheap
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
