Old 02-22-2013, 10:09 AM
SMUBMW SMUBMW is offline
Mein Auto: 2008 335i Coupe
Noise when unlocking car with remote
Just recently when I unlock my 2008 335 Coupe with the remote, when it unlocks, there is a residual noise being made that sound almost like a drill that last 3-5 seconds. This only happens when the car has sat for an hour or more. It does not happen if you use the remote to open the trunk.
Has anybody else had a noise like this?
Old 02-22-2013, 10:34 AM
tturedraider's Avatar
Freedom isn't free!!
A failing lock actuator makes a sound like a jackhammer. Is the sound anything like that?
www.bmwcca.org
Old 02-22-2013, 10:39 AM
TXFred TXFred is offline
Mein Auto: 2008 335i Convertible
It's your fuel pump. The car is just getting ready to go for a drive. Totally normal.
Any idiot can be fast in a straight line. The corners are what separates the drivers from the commuters.
Old 02-22-2013, 11:43 AM
Zooks527's Avatar
Zooks527 Zooks527 is offline
Winding up the M235xi
+1 This.
A more aggressive prime of the HPFP is what seems to have solved the recurring failures seen through 2010. After my car received the software upgrade as part of the HPFP recall replacement, the pump priming became much more noticeable.
