E30 (1982 - 1993)
Old 02-22-2013, 10:40 AM
DocNessMonsta DocNessMonsta is offline
Mein Auto: Currently nothing
These damn starters
Anybody got any tips on how to get easier access to the starter bolts on an E30 coupe w/manual trans?
Old 02-22-2013, 01:06 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
What I did was take the hood off. Take the lower motor mounts bolts off, get a engine crane and hook on the front loop up top. Lift up motor to get enough angle to see the bolts. Use about 3 foot of extensions to get up there and crank away. Thats how I did my clutch set up, which is essentially the same process minus removing transmission.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 02-22-2013, 02:05 PM
SWISS SWISS is offline
On Top
Send a message via AIM to SWISS Send a message via Yahoo to SWISS
Mein Auto: E30 S52 / S52 M roady
Remove 3 13 mm strut nuts, remove calipers, remove 13mm bolt in steering knuckle, disconnect ground strap, remove 4 engine cradle bolts and lower.
It's that simple see.
Old 02-22-2013, 02:54 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
sure is a prick of a job with the engine installed. you usualy need 2 people to do it, one coming in from under neath to hold the nut on the back of the bolt, and one on the front to undo it. you could also undo the rear transmission mounts and support the transmission with a trolley jack, and let the whole engine/gearbox assy to tip downwards. this will give you more clearance
if you are buy yourself, just pull the engine, takes about an hour to remove, but its either that or remove intake and/or brake master cylinder, depending how much room you need and how big your hands are.
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 02-22-2013, 07:22 PM
downhiller's Avatar
livin large
thats an epic win there. also had a great laugh too.
Old 02-26-2013, 10:53 AM
Well damn, so essentially there is no easy way to do it then eh? I'm by myself & I have no intention of pulling the motor just to do the starter. Thanks guys, guess I'm just gonna have to suffer through this.
Old 02-27-2013, 12:32 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
DocNess, it is still a lot easier than removing anything from a R5 Turbo
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
