Old 02-22-2013, 01:09 PM
Sjon Sjon is offline
Just arrived
Mein Auto: E46 M54226S1 Touring
Installing GPS tracker with fuel cut-off
Hi
I have a GPS tracking system in my 2009 E70 with the M57N2 diesel that can execute a fuel cut-off when instructed via SMS. A relay will then break the chosen circuit, which in the enclosed manual is proposed to be the +12V going to the fuel pump.
So far I've figured out that my car has two low pressure pumps in the tank, and one high pressure pump on/in the engine, as well as a "control unit for fuel pump" (part no. 16147276046). I'm hoping for advice regarding what is the best place to put the relay that the GPS tracker controls. I'm hoping that there is a relay that controls the two low pressure pumps, and if so, I would like to attach my relay to that one. But so far I have not been able to source enough literature to locate any related relays, and have absolutely no clue as to what the abovementioned control unit does...
Any opinions on this? Help would be greatly appreciated!
P.S. Other ideas than fuel cut-of are welcome! Instead of actuating the relay I guess I could set of all the airbags ;-)
Old 02-22-2013, 01:22 PM
jashearer jashearer is offline
Mein Auto: Holden Wagon & Sedan
The fuel pump uses fuel as lubrication and cooling, I would be hesitant about cutting the in tank pumps and starving the High Pressure unit. If I could be assured that the high pressure pump won't continue to run when the car dies it may not be as big of a deal.
I guess this is also just a last resort if it gets stolen, so maybe having a car with a burnt out expensive @ss fuel pump is better than having no car at all???
Jay
Rover - 2013 Holden Commodore SV6 Sedan
Clark - 2013 Holden Commodore Sport SV6 Wagon
Brumby - 1955 Holden FJ Ute
Old 02-22-2013, 02:47 PM
Die Wolfe's Avatar
Die Wolfe Die Wolfe is offline
Mein Auto: '12 535i Msport/'13 X5M
Originally Posted by Sjon View Post
Hi
Wow, GPS tracker?! That's awesome dude! It would be perfect here in California; I didn't expect it to be as much of an issue in Norway. It's also perfect to keep tabs on the wife or valet, LOL!
2013 BMW X5///M
2012 BMW 535i M Sport
Old 02-22-2013, 03:06 PM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
BMW electrics are extremely precise. Are you sure you want to be screwing around with them?
Old 02-22-2013, 06:32 PM
digdesign digdesign is offline
Mein Auto: 2008 4.8i
Another option could be to cut power to the drive by wire.
- Mick D.
Old 02-22-2013, 08:36 PM
JohnMN JohnMN is offline
Mein Auto: X5 35d, S4, V50 T5
Perhaps you could hook it to your door switch. An open door throws the vehicle into park. Maybe not the best idea if they're moving at any rate of speed, though.
Old 02-22-2013, 09:48 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
That's a very interesting idea. Since door switches can malfunction, and BMW is very safety conscious, I'm pretty sure that BMW has designed into the system something which will prevent an open door signal from putting the transmission into park until the vehicle has slowed down enough or come to a stop, which is probably the best type of shutdown to avoid an accident, e.g., do you really want to shut-down the vehicle while it is operating at high speed on a busy highway, perhaps causing a multiple-car accident?
That said, I am always a bit nervous when non-factory accessories are added which can shutdown the vehicle -- if the device malfunctions, or installation problems such as a bad connection appear over time, you become the victim of the vehicle shut-down. Depending on the vehicle theft risk of your location, it is a trade-off of the likelihood of the vehicle being stolen vs. the likelihood of a malfunction impacting your own safe operation of the vehicle.
Old 02-23-2013, 01:09 AM
Just arrived
Thanks to all wo have replied so far. You guys mention several things that needs to be considered.
c xwes
Jay
Good point. I guess it would be best to cut power to the HP pump then. And as you say, this would really be a last resort.
No, not yet
What would be the effect of this?
JohnMN and Penguin; this i really interesting. I absolutely do not want to cause an accident (at least not one where innocent people gets injured), nor do I want to install a solution that - if it fails in the future - leaves me stranded roadside.
I will have to look into how an open door affects the transmission at different speeds.
That being said, theft of these and similar vehicles is not uncommon where I live, but luckily not as big a concern as, say, in the UK (300 2004-2012 BMWs stolen in a month IIRC). I have moved the OBD II out of the ultrasonic sensors blind spot, but still would like the peace of mind of being able to interrupt thieves in one way or another.
Old 02-23-2013, 06:59 AM
I love the idea of hooking it to the accelerator pedal, cut that and the car will continue to run but will coast to a stop in theory
Jay
Old 02-23-2013, 09:02 AM
Jay explains it well...
- Mick D.
Old 02-23-2013, 01:32 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i M Sport; 328i Wagon
I am opposed to anything which could cause an accident. IMHO it would be far more effective / non-violent to have the car coded to blast out Justin Bieber MP3's at maximum volume.
Either that or a remote control Taser mounted under the steering column, pointed at the driver's crotch.
Current BMW's:
2014 535i MSport Space / Black, ZCW, ZDA, ZLP, ZLS, ZPP, H-K and 704
2015 X1 28i xDrive Alpine / Black, xLine, ZCW and Ultimate
2015 X1 35i xDrive Black / Black, ZCW, Ultimate and Xenons
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 02-23-2013, 02:51 PM
Die Wolfe's Avatar
I agree with the Taser idea...but what if the "would be thief" was an adolescent teen who had the Bieber fever?!
2013 BMW X5///M
Old 02-23-2013, 03:19 PM
Just arrived
Agreed, but I guess driving while getting tazed in the nuts could cause an accident as well
Jay
So far, this is my favorite idea! How would you go about this, installation-wise? Does the drive by wire control only the accelerator pedal, or would other controls/instruments be affected? I have not been able to find any technical description of the system.
If I'm lucky, it is a separate system with its own +12V supply, but I'm afraid it's more integrated and complicated than that
This is great, thank you all for contributing so far.
Old 02-23-2013, 03:34 PM
And you think that wouldn't cause an accident?
Old 02-23-2013, 03:45 PM
NoI4plz NoI4plz is offline
Mein Auto: A box with 4 circles
Understandable if your not comfortable to answer, but why?
Pretty much all the opinions above are useless without one critical piece of advice...Whats the programming behind all of the control units that you wish to disable. If you try to mess with those right now, you run the risk of messing with proper drive-ability currently.
The best answer to your query is asking a BMW engineer, BMW themselves (they make armored versions of the X5), and or companies that armor and build BMWs for dignitaries or such. They are the only ones who needs to shutoff a moving vehicle by disabling a core power-train component without causing a crash of some sort.
Good Luck!
BMW and Mercedes Build Beta Products!
Lexus build Release Candidate Products!
Why does this matter?
CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world!
fuel cut, fuel pump, gps, relay, relay curcuit, tracking device
