Old 02-23-2013, 06:16 AM
ductman's Avatar
ductman ductman is offline
Mein Auto: 2011 X5 35D /2011 M37X
Could this be an issue with our Diesels ?
Came across an article concerning rising oil levels in diesel engines, one of the causes is fuel dilution ( diesel fuel in the crankcase ) , this can happen in many ways from incomplete DPF regeneration cycles or leaking injectors, I know on mine my crankcase has always been at max level for the duration of the 10k interval but never has shown the overfilled warning. If you Google " rising oil levels in diesel engines " this issue is not confined to any one brand.
Old 02-23-2013, 06:36 AM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
An oil analysis will give you a measurement of fuel dilution if you're concerned.
Old 02-23-2013, 07:17 AM
jashearer jashearer is offline
Mein Auto: Holden Wagon & Sedan
Its absolutely a real possibility when a manufacturer uses post injection to get un-burnt fuel down into the DPF for the regen instead of using a separate injector in front of the DPF. I know the General switched to having a separate injector, I think every other brand uses a post injection squirt though.
As mentioned, you can ask for a sample and do a UOA if you are worried about it, I would be interested in seeing a statistically relevant sample from the D drivers on here.
Jay
Rover - 2013 Holden Commodore SV6 Sedan
Clark - 2013 Holden Commodore Sport SV6 Wagon
Brumby - 1955 Holden FJ Ute
Old 02-23-2013, 10:11 AM
Jay
Here's a single analysis which shows minimal fuel dilution:
http://www.bimmerfest.com/forums/sho...d.php?t=475850
Old 02-23-2013, 02:57 PM
AutoUnion's Avatar
AutoUnion AutoUnion is online now
Mein Auto: Deutsch Automobil
OP, thanks for this interesting topic. I know people over at TDIClub.com have been debating this for a while now.
I was reading up about the upcoming Mazda diesels and they were suffering from this issue and they needed frequent oil changes (much more than the usual BMW/VW/Audi/MB ~10k miles) to alleviate these issues.
I think this really isn't a problem with our diesels, if it was, it would have cropped up. Same with the various VW/MB/Audi diesels out there. People have tested oil dilution at factory oil intervals on the 2.0TDI VW CRD engines and they almost always said that the oil was ok to even longer than the recommended intervals.
I did have an oil level too high message, but it was linked to a broken oil sensor, not dilution.
I think it's safe to say the Germans know what they're doing when it comes to diesels.
Old 02-23-2013, 05:10 PM
ductman's Avatar
I actually as you read about this on the upcoming Mazda diesels also, apparently in the owners manuals of the Mazda's , it states that the when the oil level rises to the " X " on the dipstick , the oil needs to be changed or risk engine damage, some people have had to have their oil changed within a couple of thousand miles !
