Old 02-23-2013, 03:51 PM
sclui56 sclui56 is offline
Mein Auto: Z4 3.0/LX-570/IS-F/560SL
BMWPEDALS Dead Pedal Install
Hi,
Received my set of pedals and there was no problem in fitting the gas & brake, however, when I laid the dead pedal over the plastic housing, I noticed the OEM housing surface is slightly concaved, which means the metal dead pedal will not sit flat and there will be voids in the middle.
I haven't installed this piece since it only uses double-sided tapes, I fear ithat every time I press against it and release, there will be this "tacky" sound.
Has anyone installed a set in the Z4 and what's your situation?
Old 02-23-2013, 07:28 PM
STIHLBOLTS STIHLBOLTS is offline
Hat's On, Tops Down!
Mein Auto: 2013 335is
I did not know there was a rest pad cover that would fit? I guess I'm still right.
I searched high and low and finally went with the OEM M peddle set, gas peddle, clutch and brake, no foot rest pad cover, that is still black.
I guess if you want to keep your's, you will have to mash it down to be concave too. So I would make sure you really like it before doing that or the MFG might not take it back.
2013 335is Convertible
MODS:M3 Strut Brace / Smart Top Module / Ikon Lip and spoiler
BMWCCA Member
Previous: 2004 3.0 Z / 2008 Z4M
Old 02-23-2013, 08:35 PM
daven daven is online now
Mein Auto: 1999 BMW Z3 Coupe
Use a couple beads of silicon caulk. It'll fill the gaps, cushion the pressure and peel off when you get tired of the bling.
David
Blue Ridge Mntns, NC
1999 2.8l Z3 Coupe
Arctic Silver
Old 02-23-2013, 10:42 PM
I am not going the bend the piece to fit because the curvature is not even and I cannot control the bend, I will just return the dead pedal piece. Only reason I went with the BMWPEDALS was because of the completeness of having the dead pedal, otherwise I would have gone with the OEM set. Overall, I am happy with the outcome...
Old 02-24-2013, 08:02 AM
Looks good.
BMWCCA Member
Old 02-24-2013, 09:32 AM
AustinZ3 AustinZ3 is offline
Teenage Speed Demon
Mein Auto: Z3 2.5i Roadster
Good Look. thinkin about finding some for myself
2001 Z3 2.5i, Spyder Halo Headlights, Kicker CompVT65 Subwoofer, LEDGlow Million Color Underglow Set
Old 02-24-2013, 07:21 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
That brake pedal looks so lonely all by itself!
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 02-24-2013, 09:26 PM
It is indeed. But what can I say, this is my daughter's and as much as I wanted to order the M coupe at the time, she couldn't drive a stick and I didn't want to order the stick and then figure out whether she could drive one after all.
Old 02-26-2013, 10:13 AM
SC2003Z4 SC2003Z4 is offline
Mein Auto: '03 Z4 2.5i Silver/Black
I have to agree with Daven...clear silicone will do the trick and the job will look "complete". You don't have to put on a ton of it...just a little where the gap is present then lean something with just a little weight against it overnight and you're good to go. Since silicone does not expand as it dries, it will be completely unnoticeable.
Javier 03 E85 2.5i
Old 02-26-2013, 12:59 PM
barryb97 barryb97 is offline
Mein Auto: 06 M Coupe, 01 X5 4.4i
Hmm. I installed these on my M and there is no visible gap. I do get an occasional light pop from the dead pedal when the tape "adjusts" itself. They look and feel great!
CDV delete, clutch stop, BMW pedals, Strongstrut bar, SS brake lines, radiator hole cover, brake duct stop removal, Gunmetal M3 reps, roundel under hood, Intravee II ipod adapter, Homelink, air bag sticker delete, first aid storage under seats, Bumper plugs keyhole cover, painted reflectors, Headlight washer disable, Mstache front lip, Autosolutions SSK, Leather Z arm rest, Stromung exhaust, RPI scoop, RTAB limiters, powerflex bushings front, TC Kline DA coilovers…
