Old 02-23-2013, 09:57 PM
maxo898 maxo898 is offline
Mein Auto: 1997 BMW 740il
1997 BMW 740IL ABS Sensors
My abs light has been on since i baught the car so i went and baught 4 other wheel speed sensors and replaced the. The old ones were ripped. The light is still on how can i get rid of it.
Old 02-23-2013, 10:21 PM
Pabliniboy Pabliniboy is offline
Mein Auto: 06 530i
Abs light
Is only the abs light on? Have somebody get the codes, my money is on the abs module
Old 02-23-2013, 10:56 PM
There is a yellow triangle in the middle with a circle arrow and the check engine light p0500 vehical speed sensor
Old 02-24-2013, 08:54 AM
Mein Auto: 06 530i
And your speedometer is not working right?? Replacing a ABS control
Module will fix that. It will need to be coded if you replace it...there is a company that
Repair the modules, you will have to take it apart and mail it is about $200-300
Old 02-24-2013, 10:06 AM
If i buy a used abs module what serial numbers need to match so i wont have to get it coded. Before my speedometer stopped working everything was the same. the ABS CEL(P0500) Yellow Triangle were on. Also my MPG & Mileage(Paused) stopped working. The Gas gauge goes back and forth and brakes work perfectly fine. If i disconnect the abs module for an hour will anything happen.
Old 02-24-2013, 11:45 AM
Mein Auto: 06 530i
No is not going to make a difference if you disconnect your battery..
If it was me having that problem and I'm keeping the car for some years
I wouldn't put a used module, cuz that is a common problem and that module
May get faulty too... And if you go for a used module the donor car
Needs to have the same options as yours..... But there is a big chance
That it will have to be recoded to yours... Hope this help you!
Old 02-24-2013, 11:48 AM
HTML code is Off
